Easiest way to remove rear control arm self tightening nut?, Is there something that I am missing? |
Zaney |
Jun 19 2009, 01:43 PM
Deuchland en der Haus Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest |
Title says it all!
I am trying to loosen the two 22mm nuts that hold the rear control arm pivot point to the car's suspension console. I assume they are righty tighty & lefty loosey. Do I need to heat them up a tad to free them? Already used penetration oil on them with no luck. Is there a trick to this? Thanks in advance!!! (IMG:style_emoticons/default/confused24.gif) Nate |
SLITS |
Jun 19 2009, 01:59 PM
Gorilla Wrench?
I haven't had the problem with my cars, but I don't live in the soggy side of nowhere. Self tightening ..... I don't think so ..... self locking is the term I think is correct. |
charliew |
Jun 19 2009, 02:07 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I guess the easiest is with a cutting torch or a cutoff wheel if the impact won't do it. You can blow the side of the nut off without hurting the threads. Also they make nut splitters. If the nut is that rusty the shaft inside is probably also pretty bad.
McMark |
Jun 19 2009, 02:41 PM
You're using a 22mm wrench right? Not an adjustable wrench. Nothing special about them. Just use the right tools and push/pull hard.
Zaney |
Jun 19 2009, 02:58 PM
Lo-Fi Version | Time is now: 7th June 2024 - 04:59 AM |
