Zimms |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,415 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest ![]() ![]() |
Just want to know if this is correct. They were easy to install, but there was no cursing or round II that I normal go through, so the whole thing feels weird. Here is what the installed mount looks like. Is this correct?
![]() Thanks! |
lotus_65 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,609 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region ![]() |
never looked at one up close. looks really nice!
no washers other than the bottom big'un? |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Looks good. I'd take the time to get some appropriate length bolts. Extra threads are ugly. (IMG:style_emoticons/default/cool.gif)
WEvo makes nice stuff and takes the time to make sure it works. So no cursing is their standard. (IMG:style_emoticons/default/biggrin.gif) |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Looks like mine.....after I tightened things up. I hope we're right. (IMG:style_emoticons/default/biggrin.gif)
Attached thumbnail(s) ![]() |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,266 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
These look great. Let me know what the "sound" difference to preformance ratio is? I know this is subjective but just an opinion.
Rob |
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
I would still use the cup washer that prevents it from popping out of the transmission
wing thingy. Attached image(s) ![]() |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
QUOTE no cursing is their standard. execpt when you write the check... |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
I installed mine when they first came out, and they look just like the above post's pics. Nicely done aftermarket parts, really first rate. They have helped with the shifting, and do not transmit any more vibrations from the drivetrain to the body.
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
I second that you should use the big cup washer on the top to keep it form sliding off.
Zimms |
Thanks everyone. I am going to add the big washer thingy tomorrow.
McMark |
QUOTE no cursing is their standard. execpt when you write the check... Let me know when you find the "Well Designed & Well Built, FOR CHEAP!" store. (IMG:style_emoticons/default/rolleyes.gif) |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I second that you should use the big cup washer on the top to keep it form sliding off. (IMG:style_emoticons/default/agree.gif) |
brp986s |
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 ![]() |
It seems there should be material around the tabs. If one snapped, the others would snap in quick succession. I guess as long as there no reports of such I'll (IMG:style_emoticons/default/yellowsleep[1].gif) in peace.
tat2dphreak |
QUOTE no cursing is their standard. execpt when you write the check... Let me know when you find the "Well Designed & Well Built, FOR CHEAP!" store. (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/biggrin.gif) didn't say it wasn't WORTH it, but sometimes those checks are hard to write, even if you know you have to write it... |
Zimms |
I would still use the cup washer that prevents it from popping out of the transmission wing thingy. Chappy, What did you use as a spacer? Did you turn that down? ![]() I went to use the cup washer, but the WEVO mount does not sit flat in it. The washer is too big. , so the mount doesn't seat in cup. I guess I am off to the hardware store for some washers. Diameter of washer compared to the cup: ![]() Gap between the bottom of the cup washer and the WEVO washer. ![]() Standard mount sitting flush. ![]() |
J P Stein |
I'm not gonna add the big washer. I'll let ya know in the trans falls out.....don't hold your breath. (IMG:style_emoticons/default/biggrin.gif)
iamchappy |
I used the stock thick washer that was there before...I think.......
Zimms |
My old mounts just went straight into the rubber mount. I ended up using a few washers, 1 3/8" OD, stacked to 3/16" high, and it did the trick.
![]() All done for now. Time to move the fuel pump and sort out some wiring gremlins. |
tat2dphreak |
QUOTE no cursing is their standard. execpt when you write the check... Let me know when you find the "Well Designed & Well Built, FOR CHEAP!" store. (IMG:style_emoticons/default/rolleyes.gif) I was browsing the wevo site yesterday, these aren't even that $$ anymore, they were much more when they were first introduced IIRC. for the current price, I think they are probably a great value... their other products are still $$ tho (IMG:style_emoticons/default/poke.gif) |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Better go back and get 4 8mm bolts 10 mm longer, add 2 flat washers on each one, and use nyloc nuts. Gonna look pretty silly draggin' that tranny down the road when those plain nuts back off ..............................
The Cap'n |
Lo-Fi Version | Time is now: 11th July 2025 - 04:48 PM |
