Wounded Sway Bar, could this still work |
EyeTrip |
Jun 20 2009, 02:31 AM
Member Group: Members Posts: 104 Joined: 29-May 07 From: Camas, Wa Member No.: 7,767 Region Association: None |
Can I weld this up or use this on a street stock setup?
Attached image(s) |
914Sixer |
Jun 20 2009, 07:38 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Not sure if the torque on the the bar would break the weld. Then again, it may last forever. It is worth a try.
aircooledtechguy |
Jun 20 2009, 09:40 AM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I'd be more concerned about the weld ruining the sway bar's springiness (is that even a word?? (IMG:style_emoticons/default/confused24.gif) ) It's the heat treatment that makes a sway bar different from just a long, bent piece of iron. . .
Katmanken |
Jun 20 2009, 09:50 AM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
It's toast.....
Spring steel is notch sensitive meaning a crack WILL form in the notch... Feeling lucky as to when it lets go and your handling changes al the sudden????????? I agree with the above, spring steel is heat treated to be a spring, meaning it wil break (snap) if you try to bend it too much or at too sharp a radius... Welding will turn that into a nice bendable section......... |
EyeTrip |
Jun 20 2009, 08:32 PM
Thanks for the input fellas.
6freak |
Jun 25 2009, 09:10 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
I'd be more concerned about the weld ruining the sway bar's springiness (is that even a word?? (IMG:style_emoticons/default/confused24.gif) ) It's the heat treatment that makes a sway bar different from just a long, bent piece of iron. . . TORQUEAFACATION....lmao |
Lo-Fi Version | Time is now: 31st May 2024 - 05:52 PM |
