Syncro dog teeth removal? |
kyhunting |
Jun 21 2009, 03:24 PM
Newbie Group: Members Posts: 14 Joined: 8-October 07 From: KY Member No.: 8,199 |
How do you remove the syncro dog teeth from the gear???
Thanks David |
r_towle |
Jun 21 2009, 03:26 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
There is a special tool.
If you dont want to spring for the tool, see if you can borrow it. If not...they are pressed in and I have seen some people remove them starting with an old wood chisel between the dog teeth and the gear to start prying it up. Rich |
pcar916 |
Jun 21 2009, 09:02 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
And if you freeze the entire gear, then use a heat gun sparingly pointed only at the dog-teeth from the side, or gently with a propane torch with the smallest flame possible, it will separate a little easier. I have the proper tool and still use heat. Overkill maybe, but I like using temp differences to keep mating surface conditions as pristeen as possible.
Gears are hardened and I don't like to get them much over their operating temps (150 - 250 degrees) They'll take more than that without losing the temper (or case hardening) but why bother if it works between what you can get in a household freezer and boiling water, or judicious use with a heat gun, a torch or a hot-plate. An infrared thermometer is also very handy for making sure you aren't cooking it too much. Pelican Parts has the tool, which is used for both installation and removal, but if you do this without that tool, wedge up on the ring from opposite sides at the same time. |
Dr Evil |
Jun 22 2009, 12:06 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I have heard of the chisel method, but I have never done it. I always use the correct tools, but it is worth it for me to have them (IMG:style_emoticons/default/smile.gif)
If you are not in a hurry, send the parts to me and I will swapt hem for you for the price of shipping (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 09:36 AM |
