> Return of the Jedi: The legend of Narparu continues.
fiid
post Jun 26 2009, 06:47 PM
Turbo Megasquirted Subaru Member
News is that I bought a new tub, and I'm starting a new progress thread for it. I have pics forthcoming too.....
Here's my previous build thread.
Replies(1 - 19)
fiid
post Jun 26 2009, 07:06 PM
Here is the new beastie. The goal for this one is to make it somewhat nice; unlike my current car. My current car is going to be turned into a track something; maybe PCA; or maybe Lemons. Maybe both, which should nicely annoy my local PCA.
Gint
post Jun 26 2009, 08:26 PM
Mike Ginter
QUOTE(fiid @ Jun 26 2009, 06:06 PM) *
Right on Fiid! (IMG:style_emoticons/default/cheer.gif)
McMark
post Jun 26 2009, 08:42 PM
914 Freak!
Very cool! I'm definitely in for a work day. I can bring my hammer and dolly for dent bumping. Or maybe a little welding.
Or even better... (IMG:style_emoticons/default/happy11.gif) the actual motor swap. (IMG:style_emoticons/default/boldblue.gif)
Or maybe all three.
EdwardBlume
post Jun 26 2009, 08:57 PM
QUOTE(McMark @ Jun 26 2009, 07:42 PM) *
Or maybe all three.
+1
Andyrew
post Jun 26 2009, 09:51 PM
Spooling.... Please wait
Glad to see your still kickin it 914 style Fiid!
Dr Evil
post Jun 26 2009, 11:13 PM
Send me your transmission!
Missed you, Fiid
fiid
post Jun 28 2009, 05:55 AM
Aww. You guys rock. (IMG:style_emoticons/default/grouphug.gif)
I've been working on dents and welding up holes in the new tub... progress is slow; however. This is a big project.
I've been working on hammering this dent out. I think the backend has been hit before. I'm planning to weld up the badge holes and go stealth with it.
The rear decklid, btw was toast, so we made these wings out of it for our lemons car....
The PO had riveted panels in to cover up rust, so I removed all the rivets and am in the process of welding in new peices of metal where rust used to be. There's a few other places where the car has been cut and I'm putting it back the way it should be. I'm aiming for nice, tho, not concourse; so I don't mind a few weld seams here and there.
abbott295
post Jun 28 2009, 08:56 AM
I must have missed something. (Probably have missed a lot of things in my life.) But... You race lemons? I thought that's what demolition derbys were for.
fiid
post Jun 28 2009, 09:11 AM
QUOTE(abbott295 @ Jun 28 2009, 07:56 AM) *
It's a race called the 24 Hours of LeMons. Basically; you track prepare a sub-$500 car (you get to spend more than that on safety gear) and race it; endurance style for about 16 hours or so (about 8 hours per day over a weekend). It's a lot of fun; and a bit cleaner than a demolition derby; but not always *that* much cleaner (IMG:style_emoticons/default/smile.gif)
http://www.24hoursoflemons.com/
McMark
post Mar 11 2012, 08:01 PM
914 Freak!
I've been working on Fiid's new chassis and I thought I should update this thread for him, since the body is almost ready for paint.
Cleaned up some previous patching.
McMark
post Mar 11 2012, 08:03 PM
914 Freak!
We completely removed the engine shelf, since it's worthless in a watercooled car. Once this is painted it'll look like it was never there.
McMark
post Mar 11 2012, 08:05 PM
914 Freak!
More patching holes...
EdwardBlume
post Mar 11 2012, 08:06 PM
Nice work... you know how to build and save a nice car! (IMG:style_emoticons/default/aktion035.gif)
McMark
post Mar 11 2012, 08:08 PM
914 Freak!
More tomorrow... (IMG:style_emoticons/default/shades.gif)
McMark
post Mar 13 2012, 11:24 AM
914 Freak!
The first big custom project was to clean up the rough-cut front opening and then weld in diamond-punched steel. This ain't your hardware store expanded metal. (IMG:style_emoticons/default/barf.gif) Each little leg had to be welded and ground, but this stuff almost perfectly matches the stock engine grill. I used another 914 as a press-mold and formed the expanded metal to exactly the same as a stock 914.
McMark
post Mar 13 2012, 11:28 AM
914 Freak!
Replaced sections of the seal channel.
McMark
post Mar 27 2012, 05:27 PM
914 Freak!
Got a little more work done. I'm not sure if anyone's reading this... (IMG:style_emoticons/default/unsure.gif)
The driver's side door jamb had been crushed and a new fender 'installed'. It was pretty crappy work. So the fender came off, a replacement door jamb installed and then the fender was reinstalled correctly.
McMark
post Mar 27 2012, 05:29 PM
914 Freak!
The front air inlet turned out so well, we decided to use the same treatment on the fender outlet holes. (IMG:style_emoticons/default/welder.gif)
McMark
post Mar 27 2012, 05:32 PM
914 Freak!
Finally, a minimalist approach to radiator mounting. Two tube sections were welded on the bottom, and two small brackets on top are all that's needed. And there is very little modification to the chassis. The radiator is off of a modern VW and is the same unit Fiid is using in his current setup. So we know it works.
- Lo-Fi Version Time is now: 2nd April 2026 - 06:14 PM
