Proper hose - Crank breather to Carb |
TMMorgan |
Jun 29 2009, 07:04 PM
Newbie Group: Members Posts: 4 Joined: 29-June 09 From: Tafton,PA Member No.: 10,519 Region Association: North East States |
I have a '75 1.8 that a friend has given me (nicest thing anyone has ever done for me). I spent the Spring working on the electrical and I am 98% of the way there. The car was a Frankenstein of 3 cars so it has not been on the road in its current setup. I am good with electrical but a rookie with mechanical.
- Below the oil cap is what looks to be the crank case vent - On the single 4 barrel carb is an air intake fitting I called Pelican to ask if they carried a hose and they did not have a part specific for the application. A friend of mine warned me a valve should be in place to prevent oil from being sucked into the carburator. Pelican recommended I look to a VW supplier for a filter used in many VW's. Can anyone give me some direction. Picture attached. Thank you! |
neil30076 |
Jun 29 2009, 07:53 PM
Recovering dismantler! Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region |
Probably not needed - but if you want one go to your local Napa and get a generic VW bug PCV valve and install in the hose.
McMark |
Jun 29 2009, 07:58 PM
Your setup is not a factory setup, so the answer is.... whatever works.
You won't need a PCV valve. Just a piece of hose. PCV valve doesn't do anything to remove oil from the vapor, it's simply a spring loaded valve that only allows air to flow in one direction. If you're worried about oil vapor gumming up your carb (which is sometimes valid) you should look into a breather box setup. |
r_towle |
Jun 29 2009, 07:59 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
BMW oil hose...go to the dealer.
Best stuff I have found, high temp and it can handle the hot oil. Rich |
Lo-Fi Version | Time is now: 4th June 2024 - 07:52 PM |
