> Rogue Wires, Need a hand identifying where a few wires go
saigon71
post Jul 3 2009, 03:08 PM
1974/4 factory fuel injection. I have a white wire that comes out of the harness with the three wire distributor plug. Have searched high & low but can not figure out where it goes (see picture). Also, I have a broken black wire on the non-condenser side of the coil that is connected to another black wire out of the harness. Any ideas? Thanks.
Replies(1 - 7)
ejm
post Jul 3 2009, 07:37 PM
I can see the light at the end of the tunnel
Single white wire goes to the thermoswitch for the cold start valve. Pic of the other wire might be helpful.
saigon71
post Jul 4 2009, 04:34 AM
QUOTE(ejm @ Jul 3 2009, 09:37 PM) *
Thanks for the info...will post pic of the other wire as soon as I get a chance.
qa1142
post Jul 5 2009, 08:33 AM
Whiplash
is you car a 1.8L or 2.0L?
Completely different FI systems....
ejm
post Jul 5 2009, 09:14 AM
QUOTE(qa1142 @ Jul 5 2009, 10:33 AM) *
L-jet does not have the 3 wire plug to the distributor he mentions....
saigon71
post Jul 5 2009, 11:15 AM
QUOTE(ejm @ Jul 5 2009, 11:14 AM) *
It is a 2.0. Here is a picture of the coil wire that is broken. Photo was shot looking into the engine bay from the passenger side. There is a broken black wire crimped into the same connector as another black wire on the right side of the coil. The non-broken black wire feeds into the wiring harness with three other wires, another black one, a green & red one, and a white one. Still trying to figure out where the broken black wire goes. Thanks.
Dave_Darling
post Jul 5 2009, 09:39 PM
914 Idiot
Tach signal wire. Plugs into the coil (-) terminal. Look carefully for a purple stripe on the wire; that means it's definitely the tach signal wire.
--DD
cwpeden
post Jul 6 2009, 01:40 AM
Great White North, huh?
Everyone should have one of these on their desktop:
http://members.rennlist.com/914_wiring_har...rnDia_FI_GA.jpg
and one of these:
http://members.rennlist.com/914_wiring_har...a_IGN_73-76.jpg
if you have a 2.0L of course....
(thanks Jeff)
So to answer your question, white wire = thermotime switch. Its on a bracket under the intake runners.
- Lo-Fi Version Time is now: 30th April 2026 - 03:26 AM
