> The ongoing daily saga of the 914, help me diagnose
jsayre914
post Jul 5 2009, 10:22 AM
Speed Up !!!
Valves were just adjusted, 1.8 with l-jet. Car has one bad studd on cylnder #2 and there is just one nut holding the heat exchanger on that one.
car has a terrible idle, has power untill you reach a hill, you have to let up off the pedal to maintain your speed. If you press down even a little you will loose speed, and need to downshift.
today, i notice a terrible knocking sound that statrted when the car did. i drove it to work and it runs just the same (good enough) but the knocking is still there. I pulled the wire off cylender # 2 and the knock goes away, engine stumble as it should. Plug it back and the knocking continues.
It gets better....
When i give it throttle from the engine bay to stop the engine from chocking i notice a puff of smoke comes out of the cylender # 3 hole in the tin. Every time i give it throttle smoke comes blowing out of #3 hole (IMG:style_emoticons/default/WTF.gif) There is lotsa black oily residue all around that hole.
Is this a compound problem. Is it just because the exhaust is not hooked up to the head, what the %^&ck is that knocking sound??
Thanks and good day
Replies(1 - 3)
VaccaRabite
post Jul 5 2009, 12:52 PM
En Garde!
Fix the stud on cylinder #2. The exhaust leak is not helping you. On your test ride last week I could hear it popping on every downshift. If I remember you just did not have a nut that fit it. True Value usually has a really good selection of metric nuts in different thread pitches.
You may have a head leak on #3. Have you done compression testing on this engine? Leakdown?
I am at home all this week. Drive the car over on Tuesday and we can check a few things. I just have to be on the road by 5:30pm for class, so it would need to be earlier in the day. I say Tuesday only because I think I remember that being your day off. Any day is fine, so long as we are done by 5pm - since I either have to get Theo from day care, or go to class in Baltimore.
I'm off to build my 914 engine, or else I would offer to come to you.
Zach
orange914
post Jul 5 2009, 03:21 PM
http://5starmediaworks.com/index.html
sounds like a leaking head seal. do you have he original copper head gaskets in? do a compression check
jsayre914
post Jul 6 2009, 11:30 AM
Speed Up !!!
QUOTE(Vacca Rabite @ Jul 5 2009, 02:52 PM) *
Mr. (speedy) Evil said the problem with the stud might be worse than that, i did not drive it today, i am putting it in the garage tommorow, my day off to take a look.
Will also do a compression check tommorow
You know i cant come over with the teener. It only has 2 seats (IMG:style_emoticons/default/idea.gif)
thanks for the offer Zach. I will post the results tommorow, with some pics.
- Lo-Fi Version Time is now: 7th March 2026 - 04:10 AM
