Tranny Swap..Engine Tin? |
kenpolives |
Mar 6 2004, 07:43 AM
Member Group: Members Posts: 167 Joined: 31-December 03 From: Albany NY Member No.: 1,479 |
I picked with a side shifter Tranny a few weeks ago and will be putting it into a 72 to replace the tail shifter. I have 99% of the linkage but I remember reading some where I need a new engine tin piece? Is this true and if so does anyone have a part number for the piece or a pic?
Thanks |
rhodyguy |
Mar 6 2004, 07:55 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
iirc, you don't need any engine tin to do the swap ken. you do need the firewall bushing that adapts the later shift rod to the early tubs.
kevin |
brant |
Mar 6 2004, 10:42 AM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
and a motor mount with different brackets and motor bushings..
b |
kenpolives |
Mar 6 2004, 10:49 AM
Thanks for the info, I have the motor mount bar, My neighbor is a powder coater and he did it for free......
brant |
Mar 6 2004, 10:51 AM
cool...
the one thing often forgotten... (I know I did once).. is the little metal brackets that are specific to side shifters that the motor mounts go on.. (bottom of motor/above motor bar)... don't forget them.. b |
steve@ottosvenice.com |
Mar 6 2004, 10:52 AM
Member Group: Members Posts: 214 Joined: 9-November 03 Member No.: 1,324 |
You will need:12,14 (2- R&L),16 (2),19
Attached image(s) |
Mar 6 2004, 11:01 AM
Here is a veiw of the linkage so you can make sure that you have all the bits. I would replace the bushings and cone screws for a nice tight shifter from the get go. Steve
Attached image(s) |
rhodyguy |
Mar 6 2004, 11:15 AM
#24 is the one you need with the correct inside diameter for the shift rod and the correct outside demension for the earlier firewall opening. most vendors have them. the late model boot will not work without mods to the fire wall.
kevin |
Lo-Fi Version | Time is now: 10th June 2024 - 12:06 AM |
