Windshield removal- Success, How do you remove one without breaking it? |
JRust |
Jul 21 2009, 09:42 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Just what my title says. My parts car has a nice windshield. How do I get it out without cracking it?
Joe Owensby |
Jul 21 2009, 10:19 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
I removed one by: First remove the trim. Then, take a wire (I used a guitar string), and insert through the butyl rubber. Then with someone on the other side of the wire, gently saw the wire back and forth around the perimeter of the windshield. I did this one day when it was hot outside, and the rubber cut fairly easily.
jt914-6 |
Jul 21 2009, 10:25 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Of course the first thing is remove the trim. The windshield should be held in with windshield butyl. Get a very strong wire, without insulation not as thick as "mechanics" wire. Like a piano wire type. Run it through between the glass and frame. Wrap the ends around a handle of some type. You and a helper can cut the butyl by using the wire as a knife.
Glass houses have a device that heats up and they slide it around the glass seal and it melts the seal enough to remove it. Ask a glass house how they might suggest or what they would charge to remove it for you..... |
sww914 |
Jul 21 2009, 11:55 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
First- very important!
Make sure that you're not hungry or thirsty, you don't need to pee, there aren't any screaming kids or fighting dogs around, and that your blood levels of nicotine, alcohol, THC, caffeine, and anitdepressants are correct. I use one of those new retracting blade utility knives, nice and thin. Remove the trim, put a new blade in your tool and cut the butyl rubber from the inside, all the way around, at least twice. Don't push hard, the window should come right out when all the butyl tape is cut. |
Drums66 |
Jul 22 2009, 01:55 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
[quote name='sww914' date='Jul 21 2009, 10:55 PM' post='1193947']
First- very important! Make sure that you're not hungry or thirsty, you don't need to pee, there aren't any screaming kids or fighting dogs around, and that your blood levels of nicotine, alcohol, THC, caffeine, and anitdepressants are correct that's a very good starting drill(LOL).......but I'll add one. make sure your wife or girl is taken care of also!! (IMG:style_emoticons/default/idea.gif) |
plymouth37 |
Jul 22 2009, 02:52 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
Hire someone who knows what they are doing to remove it for you. (IMG:style_emoticons/default/biggrin.gif)
Last time I tried to remove one myself it came out in 1-2 million pieces, that may have just been operator error though. (IMG:style_emoticons/default/sawzall-smiley.gif) |
Katmanken |
Jul 22 2009, 09:42 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
I've broken two with the original factory heat softened adhesive strip with the heatable wire in it.
That stuff is like a brick when it's not heated..... |
JRust |
Jul 22 2009, 11:27 PM
It was hot out which definately helped. I used a utility knife & just kept working my way around from the inside. The puddy/glue was soft & prety easy to work with. Success (IMG:style_emoticons/default/biggrin.gif) . Other than the windshield being dirty it isn't pitted or cracked (IMG:style_emoticons/default/blink.gif) . Nice OEM windshield for a backup
Attached image(s) |
914four |
Jul 22 2009, 11:53 PM
Senior Member Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States |
sww914 |
Jul 23 2009, 12:35 AM
Sweet!
I hope my zen suggestions helped. |
JRust |
Jul 23 2009, 01:39 AM
Sweet! I hope my zen suggestions helped. I was fairly loaded on Wild Cherry Pepsi. SO I think the caffeine level was good. The utility knife worked excellent also. Your tips worked perfectly (IMG:style_emoticons/default/beerchug.gif) |
edwin |
Jul 23 2009, 07:31 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
unfortunately i broke my screen getting it out and i am based in Australia try finding a new one local.
on another car i knew the screen would be hard to get out so i got one of the best places in town to get it out. it shattered and still had to pay for the service. after watching the "pros" do it i didnt feel so bad. Edwin |
Lo-Fi Version | Time is now: 7th June 2024 - 01:26 PM |
