Need some help, splitting the engine case |
ottox914 |
Jul 21 2009, 10:24 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
As many of you know, I've been on a quest to build a turbo type IV. I have sent Jake and Len some money and parts to be re-built, to as to build a better beast. I need to get the case split and get the crank and rods to Jake. The motor is torn down to just a case, rods, crank, and cam. I've got Jakes video and Tom Wilsons book. I tried the screwdriver on the front seal area as the video suggests, nothing. I tried 2 dead blow hammers per Wilson, nothing. I'm 99.9% sure I got all the bolts.
Anyone with some BTDT to share, or some secret trick that has worked for you in the past? I need to get that case split and on its way, along with the guts (crank and rods). |
ConeDodger |
Jul 21 2009, 10:26 PM
Apex killer! Group: Members Posts: 23,612 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Dave,
McMark has a how-to in the Lapuwali Classics Forum on just that subject. He enumerates the bolts, points out the hidden ones that get missed. I believe a few taps with a mallet splits it once everything is unbolted. |
type2man |
Jul 21 2009, 10:29 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I'm .1 % sure that you are missing one or more bolts to split the case. There's some on the flywheel end that are barely visible and there's the small nuts on the breather box area. Also one on the side of the case under the pushrod tubes in the middle... keep looking, youll find them...
r_towle |
Jul 21 2009, 10:39 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Take a break.
Then go look and follow the case seam all the way around..keep looking. Rich |
Dave_Darling |
Jul 21 2009, 11:59 PM
Every time anyone has a problem splitting the case, it's because they've missed a bolt.
(OK, there are a few unfortunate souls who should have paid attention to the ten pounds of RTV glopping out of the seams.... (IMG:style_emoticons/default/wink.gif) ) --DD |
dangrouche |
Jul 22 2009, 01:27 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
yeah i was splitting a type 2 case just for entertainment and it was gunked up with grime and thought it would split easily and was able to to pry it slightly like jake says in his video but it did not split and I found the last one near the sump. just folllow the seam tracing it physically with a pencil or probe. you'll find it
cwpeden |
Jul 22 2009, 01:53 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
ottox914 |
Aug 2 2009, 06:41 PM
Found the .1%. Case is split. Missed one (^*%@$# bolt.
Lo-Fi Version | Time is now: 8th June 2024 - 10:42 AM |
