Busted stud going into pedal cluster - Suggestions? |
rbmorrisiii |
Jul 23 2009, 10:41 PM
Newbie Group: Members Posts: 11 Joined: 21-July 08 From: OAKLAND, CA Member No.: 9,333 Region Association: Pacific Northwest |
So when loosening one of the rear nuts holding the pedal cluster plate in (interior side) I completely broke the stud. It basically sheered flush with the floor of the car.
Now what? Is the stud a bolt thats welded to the underside? I'm just after function here, but don't want the solution to be hideous. Drill it out? Forget about it, and coast with three nuts in? Drill a new hole/insert new bolt/stud? What do you think? Thanks! |
drive-ability |
Jul 23 2009, 10:48 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
So when loosening one of the rear nuts holding the pedal cluster plate in (interior side) I completely broke the stud. It basically sheered flush with the floor of the car. Now what? Is the stud a bolt thats welded to the underside? I'm just after function here, but don't want the solution to be hideous. Drill it out? Forget about it, and coast with three nuts in? Drill a new hole/insert new bolt/stud? What do you think? Thanks! I wouldn't worry, you can drill it out and install a flat headed stud. I would think you could also just go with 3. I wouldn't its too easy to drill and replace it with a nut bolt combo. But you can see what I did to my car and consider the source. LOL |
Lo-Fi Version | Time is now: 8th June 2024 - 04:51 AM |
