Is there a way to tell which engine came stock on my 914? |
ubii |
Jul 28 2009, 03:22 PM
Newbie Group: Members Posts: 5 Joined: 20-July 09 From: Lawson, MO Member No.: 10,586 Region Association: None |
I know this might be a dumb question, but is there any way to tell which engine (1.8 or 2.0) came stock from the factory on my 914? I recently bought what I thought was a 1975 2.0, only to later discover that according to the engine serial number (EC044801), that it really is a 1.8. The PO listed it as a 2.0, only because it had the 2.0 emblem on the back and unfortunately I was dumb enough not to verify the engine serial number before I bought it . (IMG:style_emoticons/default/headbang.gif) The fuel injection system has been completely gutted and has been replaced with a single carb, so I do not know if it originally came with a L-Jet or D-Jet. I am simply trying to figure out if this 914 originally came with a 2.0, which was later replaced by a 1.8 for some reason or if it originally came with a 1.8 and someone mistakenly added the wrong emblem later on. The engine serial number does appear to be within the range for 1975, which is (EC 0037552 - EC 0045072), but all this does is confirm that the engine and car were built the same year. I guess in the end, it doesn't really matter, though it would be nice to know if this is the original engine or not.
VIN Info - http://www.914world.com/bbs2/index.php?act...mp;viewid=12405 Thanks, ubii |
underthetire |
Jul 28 2009, 03:30 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Could be a rebuild. 3 stud head or four ?
dr914@autoatlanta.com |
Jul 28 2009, 03:31 PM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I know this might be a dumb question, but is there any way to tell which engine (1.8 or 2.0) came stock from the factory on my 914? I recently bought what I thought was a 1975 2.0, only to later discover that according to the engine serial number (EC044801), that it really is a 1.8. The PO listed it as a 2.0, only because it had the 2.0 emblem on the back and unfortunately I was dumb enough not to verify the engine serial number before I bought it . (IMG:style_emoticons/default/headbang.gif) The fuel injection system has been completely gutted and has been replaced with a single carb, so I do not know if it originally came with a L-Jet or D-Jet. I am simply trying to figure out if this 914 originally came with a 2.0, which was later replaced by a 1.8 for some reason or if it originally came with a 1.8 and someone mistakenly added the wrong emblem later on. The engine serial number does appear to be within the range for 1975, which is (EC 0037552 - EC 0045072), but all this does is confirm that the engine and car were built the same year. I guess in the end, it doesn't really matter, though it would be nice to know if this is the original engine or not. VIN Info - http://www.914world.com/bbs2/index.php?act...mp;viewid=12405 Thanks, ubii |
McMark |
Jul 28 2009, 03:44 PM
The engine's are swapped more than the emblems. So I'd trust the emblem before the engine.
Cap'n Krusty |
Jul 28 2009, 03:49 PM
1.8s had an air cleaner bracket bolted to the chassis on the left side of the engine compartment. Look for signs it was there. 2.0s had the Manifold Pressure Sensor bolted through rubber grommets to a bracket just below and aft of the battery, right next to the point where the fuel lines clamp to the body. Look for signs the MPS was bolted there. The emissions sticker "might" provide some clue. It was in the area of the relay board on the left side.
The Cap'n |
ubii |
Jul 28 2009, 04:19 PM
Hey Folks,
Thank you for the quick responses, here a couple of quick and dirty snap shots of the areas you mentioned. Thanks, ubii |
underthetire |
Jul 28 2009, 04:26 PM
For sure not 2 liter heads.
McMark |
Jul 28 2009, 06:07 PM
1.8. The platform by the relay board is the giveaway.
ubii |
Jul 28 2009, 06:21 PM
Mark,
Is that what can be seen in the bottom left-hand corner of my third photo? Thanks, ubii |
neil30076 |
Jul 28 2009, 07:17 PM
Recovering dismantler! Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region |
Cap'n Krusty |
Jul 28 2009, 07:38 PM
Just as I said earlier ................. Double relay's there, too.
The Cap'n |
ubii |
Jul 28 2009, 09:54 PM
Who knows how or why the 2.0 emblem ended up on the car, but at least, now I know that it originally came from the factory with a 1.8. Thanks again for all of your help.
Thanks, ubii |
SirAndy |
Jul 28 2009, 10:03 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Who knows how or why the 2.0 emblem ended up on the car So the PO could sell the car to you for more money?!? (IMG:style_emoticons/default/popcorn[1].gif) Andy |
Todd Enlund |
Jul 28 2009, 10:11 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
Who knows how or why the 2.0 emblem ended up on the car So the PO could sell the car to you for more money?!? (IMG:style_emoticons/default/popcorn[1].gif) Andy (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/av-943.gif) sorry. (IMG:style_emoticons/default/dry.gif) |
ArtechnikA |
Jul 29 2009, 05:44 AM
Who knows how or why the 2.0 emblem ended up on the car, but at least, now I know that it originally came from the factory with a 1.8. Andy's response is probably at least partly true. There are guys who will paste 'Type R' stickers or 'Turbo' emblems on cars in the vain hope of inflating their egos by admiration of the unsuspecting. But don't feel bad - there are lots of people who think their 911's are 'S's because they can't see past the red spray paint on the fan shroud to the engine type number... FWIW - unless you're hoping to compete in national-level Concours d'Elegance, no one really cares what engine the car came with, or what's there now. I agree the history is nice to know so I applaud your research. Put in whatever engine you like, or do what you want to that one. IMO - it's about the driving, not the stickers... |
type47 |
Jul 29 2009, 07:54 AM
Who knows how or why the 2.0 emblem ended up on the car, but at least, now I know that it originally came from the factory with a 1.8. Andy's response is probably at least partly true. There are guys who will paste 'Type R' stickers or 'Turbo' emblems on cars in the vain hope of inflating their egos by admiration of the unsuspecting. But don't feel bad - there are lots of people who think their 911's are 'S's because they can't see past the red spray paint on the fan shroud to the engine type number... FWIW - unless you're hoping to compete in national-level Concours d'Elegance, no one really cares what engine the car came with, or what's there now. I agree the history is nice to know so I applaud your research. Put in whatever engine you like, or do what you want to that one. IMO - it's about the driving, not the stickers... Nicely put. This will give you the chance to get rid of the single carb and put on the real fuel injection system! (IMG:style_emoticons/default/idea.gif) |
IronHillRestorations |
Jul 29 2009, 08:26 AM
I. I. R. C. Group: Members Posts: 6,729 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Yea, I saw a "tech article" in Mid Engine Views ( the 914 Owner's Association publication) about 20 years ago that said (para-phrasing) putting a 2.0 sticker on your 1.7 or 1.8 was the easiest way to increase value!
Lo-Fi Version | Time is now: 7th June 2024 - 11:24 PM |
