What does a stripped door weigh?, Like totally stripped |
Randal |
Jul 29 2009, 09:11 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
J P Stein |
Jul 29 2009, 09:14 AM
Mine weigh 20lbs but have hinges & handles.
A F/G "skin" weighs 4-5 lbs. |
Randal |
Jul 29 2009, 09:17 AM
EdwardBlume |
Jul 29 2009, 09:25 AM
14 lbs... (IMG:style_emoticons/default/sawzall-smiley.gif)
J P Stein |
Jul 29 2009, 09:58 AM
16#
grantsfo |
Jul 29 2009, 01:00 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
A lot more than a 3 lb CF skin. (IMG:style_emoticons/default/smoke.gif)
This post has been edited by grantsfo: Jul 29 2009, 01:02 PM |
Randal |
Jul 29 2009, 01:44 PM
And the cost for that, including installation, is: |
grantsfo |
Jul 29 2009, 02:00 PM
And the cost for that, including installation, is: FG is $175 for pair. http://www.rennspd.com/P_Detail.asp?PID=376&Task=STD CF probably 10X. LOL! |
Randal |
Jul 29 2009, 02:34 PM
And the cost for that, including installation, is: FG is $175 for pair. http://www.rennspd.com/P_Detail.asp?PID=376&Task=STD CF probably 10X. LOL! OK, so CF is way expensive. FG at 5-6#'s, including fasterers, would be about $8.40 per pound, assuming about $200 for installation. |
Chris Pincetich |
Jul 29 2009, 03:30 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
No hole saw on the surrounding edges? The Hamilton/SMurf 914 has huge holes drilled all the way across the bottom and side edges as well.
I guess yours will weigh 10# each (IMG:style_emoticons/default/beerchug.gif) |
Randal |
Jul 29 2009, 05:15 PM
No hole saw on the surrounding edges? The Hamilton/SMurf 914 has huge holes drilled all the way across the bottom and side edges as well. I guess yours will weigh 10# each (IMG:style_emoticons/default/beerchug.gif) There are no edges left now. It is basically a skin with a small lip. |
Randal |
Jul 29 2009, 08:09 PM
Answer: The doors weigh 13lbs. Rob was closest at 14lbs.
So in my case there is always another 7lbs per door available by going to FG. Per pound that would be $57.00. (IMG:style_emoticons/default/shades.gif) |
brant |
Jul 29 2009, 09:09 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
We ended up at 17lbs with all metal (required for vintage racing around here)
this is with inner and outer working door handles, an interior door "panel, working hinges and a working door stop fiberglass or CF are not allowed: Attached thumbnail(s) |
EdwardBlume |
Jul 29 2009, 09:10 PM
Will the door be wavy now? or is the use of the door like so yesterday?
brant |
finished interior (also required for vintage around here)
the strap is the interior release handle. full working doors that open and close are a requirement and in our rule book This is true in many vintage clubs, I know it is in CVAR and RMVR plus many others: Attached thumbnail(s) |
RoadGlue |
Jul 30 2009, 12:51 AM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
What's a stock door weigh before it's stripped?
grantsfo |
Jul 30 2009, 12:58 AM
What's a stock door weigh before it's stripped? Depends whether its early or late model. Cars with crash bars weigh a lot more. I dont think I have seen weight for stock door with window, heavy particle board, map pocket etc. They sure felt heavy when they came off my car compared to stripped door. |
RoadGlue |
Jul 30 2009, 01:06 AM
What's a stock door weigh before it's stripped? Depends whether its early or late model. Cars with crash bars weigh a lot more. I dont think I have seen weight for stock door with window, heavy particle board, map pocket etc. They sure felt heavy when they came off my car compared to stripped door. Would be interesting to see, just to get an idea of what the overall weight savings are. Anyone have a complete early and late door that they can weigh? |
Randal |
Jul 30 2009, 09:52 AM
Randal |
Jul 30 2009, 09:54 AM
Lo-Fi Version | Time is now: 1st June 2024 - 03:40 PM |
