Fog Lamp Fitting |
Fog Lamp Fitting |
jjbunn |
Aug 1 2009, 08:34 PM
Julian Group: Members Posts: 121 Joined: 20-May 09 From: Pasadena, CA Member No.: 10,383 Region Association: Southern California |
I bought a set of the Camp914 Pilot lamps, and am just shaping up to fitting and cabling them.
There is a bunch of taped up wires emerging from the body near the fog lamp mounting point, seen in this photo: (IMG:http://farm4.static.flickr.com/3579/3778983101_05755e5017_b.jpg) (There is a similar wire bundle on the other side, too.) Are these wires for the fog lamps? I wasn't expecting to find existing wiring, as I thought fog lamps were an optional extra ... Thanks! |
underthetire |
Aug 1 2009, 08:37 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Where are the horns? Could be the horn wiring. I just put mine in yesterday. The drivers side had 2 power wires ( whitish yellow) and one brown (ground). The other side had one each.
jjbunn |
Aug 2 2009, 02:20 PM
Where are the horns? Could be the horn wiring. I just put mine in yesterday. The drivers side had 2 power wires ( whitish yellow) and one brown (ground). The other side had one each. There is only one horn on my car, on the driver's side. When you talk about the wires, are you referring to the fog lamp wires or the horn wires? If anyone has a close-up photo showing the fit of the lamps in the grille openings, I'd appreciate it. Do the lamps fit inside the opening, or set back from the opening? |
jjbunn |
Aug 2 2009, 08:58 PM
Where are the horns? Could be the horn wiring. I just put mine in yesterday. The drivers side had 2 power wires ( whitish yellow) and one brown (ground). The other side had one each. There is only one horn on my car, on the driver's side. When you talk about the wires, are you referring to the fog lamp wires or the horn wires? If anyone has a close-up photo showing the fit of the lamps in the grille openings, I'd appreciate it. Do the lamps fit inside the opening, or set back from the opening? On the passenger side I have two brown, one black, and one yellow/white. On the driver's side I have two brown and one yellow/white. I guess I need to start puzzling over the wiring diagram :-) |
Lo-Fi Version | Time is now: 8th June 2024 - 08:05 PM |
