WOT--Audi 5000CS Starter--Help Please, Rebuilt starter spins but doesn't engage |
anderssj |
Aug 4 2009, 08:29 PM
Dog is my copilot... Group: Members Posts: 1,662 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Hi all,
Tonight I picked up a Bosch re-built starter for my old Audi and spent the evening in the driveway installing it (and swatting the mosquitoes). Finally got it put in--when I turn the key I can hear the starter spin, but the engine doesn't turn over. I guess that means the pinion isn't entending/engaging. Could it be a bad solenoid? I thought that the starter shouldn't spin until and unless the solenoid extends the pinion. I've been through my Bentley manual, but it doesn't address this problem. Need to get this thing fixed as it's my DD . . . . Thanks in advance! |
r_towle |
Aug 4 2009, 09:01 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
did you hold it up side by side with the old starter?
Could be the wrong unit. Not all would be lost...you could swap the nose if you have to... Take a close look.. Rich |
anderssj |
Aug 4 2009, 09:27 PM
Rich,
Thanks for the quick reply . . . Yep, I looked at them--they looked the same, but I didn't compare them closely side-by-side on the bench . . . I figure I can do that when I take it back out (IMG:style_emoticons/default/headbang.gif) I should have been more careful, as the FLAP's first attempt was the wrong starter in the right box (noticed that the bolt pattern was off when I checked it at the store). Oh well, it wasn't a complete waste of time--the learning curve should be a little shorter next time. Thanks again, Steve A- |
r_towle |
Aug 4 2009, 09:31 PM
One of the problems I found with ordering Audi parts....they are typically the wrong part the first time.
Contact the Cap'n here....ask him for the exact part number... Then make sure that number is on the next one. Rich |
anderssj |
Aug 4 2009, 09:41 PM
One of the problems I found with ordering Audi parts....they are typically the wrong part the first time. Contact the Cap'n here....ask him for the exact part number... Then make sure that number is on the next one. Rich Rich, Thanks, I'll try the Cap'n. FWIW, there's only one PN for the type 44 cars (5000, 100, 200 up through 1991 or so). This one has the right number on the box and the starter . . . . Thanks again, Steve A- |
r_towle |
Aug 4 2009, 09:59 PM
Given that its an audi...I cant believe there is just one single option, even within the same series of cars....not something I have ever seen....but like I said....and an expert.
Rich |
anderssj |
Aug 4 2009, 10:19 PM
Given that its an audi...I cant believe there is just one single option, even within the same series of cars....not something I have ever seen....but like I said....and an expert. Rich Yeah, it surprised me too . . . . I sent a PM to the good Cap'n--looking forward to hear from him. Thanks! Steve A- |
r_towle |
Aug 4 2009, 10:24 PM
my guess is the motor is same motor, 8 different noses...so it may appear to have the right number...but.....its an audi.
Rich |
Lo-Fi Version | Time is now: 1st June 2024 - 03:20 PM |
