> help me ID my 914/4, 1972 porsche 914/4
john914/4
post Aug 5 2009, 09:44 AM
I purchaced a 1972 porsche 914/4 a few weeks back and am having a bit of trouble getting the numbers broke down. the VIN is 4722919064. it was manufactured on 06/72. the karman plate in the drivers door reads NR. 2439512. L9H. the engine was out of the car and it has a number stamped onto the block AW009121. there was a set of webers with it and I found the following on them 40 IDF 19. ? the car seems very original with very minamal rust. it cam from michigan. the color is a gold color under the red paint. I bought a 1970 914/4 a few months before I ran into this one and being the other (1970) is body is completely rusted I am going to use it for parts. I have purchaced a number of books on the 914 and some kind of point me in a direction but not very through. I am under the impresion that this is a 1800 VW bus engine. and maybe a off color. I am prepairing to rebuild the engine and I want to be able to get the correct parts. will these webers work? any help would be very greatly appeciated. this is my first porsche/VW 914. I have a 1972 El camino restored by myself so I do know cars. but these little guys are a mystery right now. thanks for reading. before I leave one more thing that I thought was interesting is the front of this 914 has no grills for the driving lights and is rounded unlike the flat fronts of all the 914's I have seen below the rubber bumper its plain and rounded (2 piece).
Replies(1 - 19)
type47
post Aug 5 2009, 09:54 AM
Viermeister
Welcome! (IMG:style_emoticons/default/welcome.png)
According to this site: http://w2.wolfsburgii.com/t2e.htm your engine is a 1.8 73-74, however, due to the age of the engine, it could be built into just about any configuration by a previous owner (PO). I don't believe there was a factory gold color offered. Could you post a pix of the bumper?
rick 918-S
post Aug 5 2009, 09:55 AM
Hey nice rack! -Celette
(IMG:style_emoticons/default/welcome.png) Yes it's a 72. Someone here has the paint codes and chip colors listed someplace. I'm sure someone will either post a link for you or you could use the search function and maybe find them.
I'm not the guy for the engine code info either. But wanted to welcome you. (IMG:style_emoticons/default/assimilate.gif)
Be sure to record the vin numbers here as well. We keep track of the cars. Specially the ones that get sacrificed for parts.
Post some pics of your new passion. (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Sleepin
post Aug 5 2009, 09:56 AM
19064th 914 built in 1972
Engine number not sure, unless it is AN instead of AW, which would be a 1975 1.8L
Your body color is missing a number, probably an L97H which was gold metallic.
Oh... and :welcome: (IMG:style_emoticons/default/biggrin.gif)
tat2dphreak
post Aug 5 2009, 09:58 AM
stoya, stoya, stoya
1st (IMG:style_emoticons/default/welcome.png)
2) AW engine code is a 73-1975 1.8 from a bus. are you getting the number from by the oil filler? just to be sure.
http://www.type2.com/bartnik/enginecodes.htm
3) your VIN is a "late" 72...
The factory changed the strut housing, ball joint, caliper and rotor at VIN 4722919032, so when you go to buy parts, buy a 73 part, not a 72... mine is the same way, and every "70-72" part I've ever bought had to go back for the 73-74 version
4) dual weber 40idfs are a common carb replacement for the factory FI.
post pics, please it probably just lost the grills, but I don't know what you mean about it being flat
post Aug 5 2009, 11:59 AM
Resident German
QUOTE(rick 918-S @ Aug 5 2009, 07:55 AM) *
Someone here has the paint codes listed someplace.
That would be us ...
http://www.914world.com/specs/914info.php
(IMG:style_emoticons/default/rolleyes.gif) Andy
Ferg
post Aug 5 2009, 12:06 PM
Cool, another Gold one, to bad it was color changed. Seems like a high number of gold, ravenna green, and orange cars were color changed.
Pic of my old Gold car the "Dijon Bomb"
jt914-6
post Aug 5 2009, 12:34 PM
Andy,
Here's a pic of my car's color tag. I see it is called Delphi Green Metallic. As you can see what it is called on my car. BTW, quickly changed the color to Ocean Blue Metallic (3AY).
john914/4
post Aug 5 2009, 03:34 PM
QUOTE(Ferg @ Aug 5 2009, 10:06 AM) *
really nice car. I will return mine to its original met. gold. I met a friend at a car show a couple weeks back that had a green 914 as you mentioned. his car is really nice. he was from germany and living over here now.
john914/4
post Aug 5 2009, 03:38 PM
QUOTE(SirAndy @ Aug 5 2009, 09:59 AM) *
thanks for the info the site has been very helpfull. I look forward to continuing to use the site.
john914/4
post Aug 5 2009, 03:41 PM
thanks for the info. the site is fantastic
john914/4
post Aug 5 2009, 03:50 PM
[quote name='tat2dphreak' date='Aug 5 2009, 07:58 AM' post='1199589']
[quote]before I leave one more thing that I thought was interesting is the front of this 914 has no grills for the driving lights and is rounded unlike the flat fronts of all the 914's I have seen below the rubber bumper its plain and rounded (2 piece).[/quote
below the front bumper is 2 metal panals with no openings. the lower panal has 2 small dimples and thats it. I have not seen these on any other 914 I have looked at. I take it when I get parts for this car I can refere to it as a 73, 1.8 liter VW bus engine? are these considered the opossed cylinder flat motor type 4. are th 40 idf's worth installing and is there rebuild kits for them.
[/quote]
tat2dphreak
post Aug 5 2009, 04:16 PM
stoya, stoya, stoya
the carb rebuild kits are readily available, I recommend aircooled.net. what is the car running on now? if it's running on the L-Jet, then leave it... if it's not running, and carbs will make it run... well, connect the dots (IMG:style_emoticons/default/biggrin.gif)
post Aug 5 2009, 08:45 PM
Resident German
QUOTE(jt914-6 @ Aug 5 2009, 10:34 AM) *
http://www.914world.com/bbs2/index.php?act...mp;sortby=sCode
L99A Delphi Green Metallic (Saturngelb-Metallic)
From the Page:
The German color names are added in (small print) where available.
Saturn Yellow Metallic is what it's called in German.
(IMG:style_emoticons/default/shades.gif) Andy
john914/4
post Aug 6 2009, 09:05 AM
QUOTE(SirAndy @ Aug 5 2009, 06:45 PM) *
From the Page:
thanks I found the code and it is origially to be a gold met. I will paint it as such as I restore it. again thanks
john914/4
post Aug 6 2009, 09:16 AM
QUOTE(tat2dphreak @ Aug 5 2009, 02:16 PM) *
thank-you for the info. when I purchased the car the engine and trans were in box's. needless to say I was and am worried. I hope its all there. there was one box with a set of weber carbs (40 IDF's). the guy had purchaced a new set of jugs and pistons but the bill of sale says they are, VW 96mm piston and cylinder BUS, 914 type IV 2 liter stroke. he paid like 301.90 for these and I don't know if they will fit the engine. it appears my engine is a 1973 VW 1.8 liter. type 2. as you can see I am a little worried going into this engine.
tat2dphreak
post Aug 6 2009, 09:55 AM
stoya, stoya, stoya
well, you will need to replace the crank and rods to use 2.0L pistons, assuming the 1.8 is still a 1.8, and wasn't rebuilt into something else.
if they are 2.0L pistons the pin height is for a 72mm(2.0) crank, with 2.0 length rods, the 1.8 and 1.7 used a 66mm crank and different rods with different pins.
if you are going to build the engine, I suggest getting Jake Raby's build video and studying it like your new favorite porno.
you can get it at type4store.com
if my engine was in a box of pieces I'd be worried too... (IMG:style_emoticons/default/biggrin.gif) but don't worry, with jake's video, and us here... we'll help
Cupomeat
post Aug 6 2009, 12:32 PM
missing my NY 914 in VA
Wayne, I don't know about you, but I only get about 4 minutes into my favorite porno...
WAIT, sorry, too much info. (IMG:style_emoticons/default/biggrin.gif)
tat2dphreak
post Aug 6 2009, 01:17 PM
stoya, stoya, stoya
no, you get your porno in 4 minute increments, there's a difference (IMG:style_emoticons/default/biggrin.gif)
john914/4
post Aug 7 2009, 03:25 PM
QUOTE(tat2dphreak @ Aug 6 2009, 07:55 AM) *
I really appresiate your help and advice. I will check the block and get a new crank and rods if needed. I will also get the vidio. again thanks.
- Lo-Fi Version Time is now: 24th June 2026 - 06:42 AM
