sixxx |
Newbie ![]() Group: Members Posts: 9 Joined: 1-February 07 From: los angeles Member No.: 7,497 ![]() |
This trans was built by Galen Bieker of WERKS II. The trans is originally out of my 914-6. It was modified to side shift and straight pull 225mm flywheel & clutch. It also uses a 930 turbo clutch cable (Stock). Trans was built with custom gears perfect for autocross or short track racing. Here are the gear ratios:
1st- AA 2nd- F 3rd- M I have original receipt for modification 4th- S 5th- X Trans works great accept 1st gear pops out & occasionally grinds. Other than that all other gears operate well. Sale includes: 225mm 911 Flywheel, clutch, t/o bearing, pressure plate, & 930 clutch cable & starter motor. Asking: $ 750 Attached image(s) ![]() ![]() ![]() ![]() |
sixxx |
Bump!
Lo-Fi Version | Time is now: 13th June 2024 - 05:07 AM |
