This trans was built by Galen Bieker of WERKS II. The trans is originally out of my 914-6. It was modified to side shift and straight pull 225mm flywheel & clutch. It also uses a 930 turbo clutch cable (Stock). Trans was built with custom gears perfect for autocross or short track racing. Here are the gear ratios:
1st- AA
2nd- F
3rd- M I have original receipt for modification
4th- S
5th- X
Trans works great accept 1st gear pops out & occasionally grinds. Other than that all other gears operate well.
Sale includes: 225mm 911 Flywheel, clutch, t/o bearing, pressure plate, & 930 clutch cable & starter motor.
Asking: $ 750
