CUSTOM 901 SIDE SHIFT TRANSAXLE 914-6, CUSTOM GEARS, 225MM STRAIGHT PULL CLUTCH + MORE |
sixxx |
Aug 8 2009, 08:25 PM
Newbie Group: Members Posts: 9 Joined: 1-February 07 From: los angeles Member No.: 7,497 |
This trans was built by Galen Bieker of WERKS II. The trans is originally out of my 914-6. It was modified to side shift and straight pull 225mm flywheel & clutch. It also uses a 930 turbo clutch cable (Stock). Trans was built with custom gears perfect for autocross or short track racing. Here are the gear ratios:
1st- AA 2nd- F 3rd- M I have original receipt for modification 4th- S 5th- X Trans works great accept 1st gear pops out & occasionally grinds. Other than that all other gears operate well. Sale includes: 225mm 911 Flywheel, clutch, t/o bearing, pressure plate, & 930 clutch cable & starter motor. Asking: $ 750 Attached image(s) |
sixxx |
Aug 15 2009, 12:01 PM
Bump!
Lo-Fi Version | Time is now: 20th May 2024 - 04:40 AM |
