picture needed |
picture needed |
JOE M |
Aug 12 2009, 08:51 AM
Member Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None |
I need a picture of the inside of an 009 distributor. I just want to make sure mine has all the bits.
tat2dphreak |
Aug 12 2009, 09:04 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
I'll get you a pic tonight, but basically you will see a rotor on top, plastic.
a set of points like a crocodile mouth that opens when the dizzy turns and a condensor hung on the outside(little barrel thing with a green wire. I will soon have a 009 compufire for sale if you want, it was only in the car for about 2 weeks. then I changed the dizzy |
JOE M |
Aug 12 2009, 10:10 AM
I'll get you a pic tonight, but basically you will see a rotor on top, plastic. a set of points like a crocodile mouth that opens when the dizzy turns and a condensor hung on the outside(little barrel thing with a green wire. I will soon have a 009 compufire for sale if you want, it was only in the car for about 2 weeks. then I changed the dizzy I need a picture below that where the weights are.I want to make sure that mine is correct. It looked like mine may be missing parts. |
tat2dphreak |
Aug 12 2009, 10:15 AM
I might have another 009 I can pull out of my spare engine I can dismantle.. I'll have to look.
JOE M |
Aug 12 2009, 11:19 AM
Lo-Fi Version | Time is now: 2nd June 2024 - 10:25 AM |
