kenshapiro2002 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,444 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region ![]() |
The stock mirrors on my 914 suck IMHO. They angle downward (not on a horizontal plane), and only adjust in and out...not up and down. Anybody have an opinion on an option that will cover the stock placement holes, is black and provides a better view?
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
several 911 mirrors have been made to work. there's the infamous vilatoni style too(which is butt-ugly imho)
but stock mirrors do adjust up/down too... I personally would like to find some small, round , CHROME ones that look period correct. or some nice Billet ones that can work in the stock location. |
Grelber |
Insert favorite Don Rickles joke here. ![]() ![]() ![]() Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region ![]() |
I have stock mirrors on both sides, and they adjust up and down as well as in and out. Yours just might be stiff.
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Carefully remove the black surround that holds the mirrored glass in place, and then you'll have access to the adjustment nut inside the mirror that controls the vertical adjustment on the factory mirror.
With a bit of penetrating lubricant and some adjustment, the stock mirror should work just fine. Most people that have changed to other mirrors seem to regret the change after a while. The stock mirrors seem to have the correct look over time. |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
I got some late 80's gm electric mirrors that several people have used that look pretty good but to me might be a tad too big. My 75 has both stock mirrors but a vandal broke the driver's mirror glass while breaking the vent window trying to steal the radio. Some one here or the club sent me a window free when I first joined as a newbe. I also have some 69 mustang mirrors that may be more period correct. They are more angular in shape. What is a guy to do. I kinda hate to make new holes in original doors.
kenshapiro2002 |
It's the angle shown in this photo that bugs me, not really the in/out or up/down adjustment. Maybe some kind of base shim that lifts the outside edge...
JJ914GT |
Member ![]() ![]() Group: Members Posts: 171 Joined: 21-May 09 From: Amsterdam Member No.: 10,386 Region Association: Europe ![]() |
I'll be using two stainless torpedo style round race mirrors. They could be fitted to your original location I guess, if you like the look.
dflesburg |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None ![]() |
send me your old stock mirrors if you dont want them. I love them! and have them on all three of my cars.
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
It's the angle shown in this photo that bugs me, not really the in/out or up/down adjustment. Maybe some kind of base shim that lifts the outside edge... ![]() It appears to me they were mounted in the wrong spot ...Need to be on the top of the door next to the seal ,,,,jmo...just looked again and i dont see plastic shimmy thingy under it .... |
6freak |
tat2dphreak |
It's the angle shown in this photo that bugs me, not really the in/out or up/down adjustment. Maybe some kind of base shim that lifts the outside edge... It appears to me they were mounted in the wrong spot ...Need to be on the top of the door next to the seal ,,,,jmo...just looked again and i dont see plastic shimmy thingy under it .... (IMG:style_emoticons/default/agree.gif) there's a little plastic gasket thing under it that belongs there... hard to tell from the angle of the pic if it's in the right spot. but my car has it mounted just like 6 freak... and I don't have the funky angle |
kenshapiro2002 |
Nah...they're right next to the seal and the plastic bases are there. You have made that light bulb go off for me though...I'm going to create a replacement shim that is thicker on the outside edge to lift the whole mirror into a horizontal plane. Thanks!
kenshapiro2002 |
Mine is obviously the stock mirror in the stock mounting area. The problem must be the plastic shim under the mirror. Is your shim thicker on the outside edge to compensate for the slope of the door where it mounts?
6freak |
I do not remember if there angeled or not .. It wouldnt take much of a wedge to get the end of the mirror to come up so maybe that little plastic shim piece does have a slight angel to it!... are your backwards??......P.S it bugs me to so hurry up and fix it ..lol
warrenoliver |
Member ![]() ![]() Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest ![]() |
I do not remember if there angeled or not .. It wouldnt take much of a wedge to get the end of the mirror to come up so maybe that little plastic shim piece does have a slight angel to it!... are your backwards??......P.S it bugs me to so hurry up and fix it ..lol (IMG:style_emoticons/default/agree.gif) I'll bet that's it - they are on backward. When I had both of mine off to repaint, I remember that if I put the left mirror on the right door, it sat at an odd angle. Try swapping mirrors left to right or take each one off and rotate the base 180 degrees - may be as simple as that. Warrenoliver |
tat2dphreak |
yep, that's what it is... the metal plate at the bottom is at a slight angle. you have it on bacwards (IMG:style_emoticons/default/biggrin.gif)
dflesburg |
send them to me
schreiber |
Member ![]() ![]() Group: Members Posts: 137 Joined: 26-June 07 From: Huntsville, AL Member No.: 7,843 Region Association: South East States ![]() |
kenshapiro2002 |
Nope...checked that out hoping that was the problem. They are correct.
yep, that's what it is... the metal plate at the bottom is at a slight angle. you have it on bacwards (IMG:style_emoticons/default/biggrin.gif) |
kenshapiro2002 |
Lo-Fi Version | Time is now: 4th July 2025 - 11:45 AM |
