3rd. and 4th. brake lights, Splicing into the main harness? |
jjbunn |
Aug 14 2009, 06:30 PM
Julian Group: Members Posts: 121 Joined: 20-May 09 From: Pasadena, CA Member No.: 10,383 Region Association: Southern California |
I have two LED brake light units that are fitted (glued) to the glass just behind each headrest of the seats (so as not to affect visibility). These I want to illuminate at the same time as the rear brake lights.
I would like to connect them into the main wiring harness that runs through the centre tunnel in the passenger compartment, since the wires are all there and it looks like an easy thing to do, but I'm wondering if this is a bad idea? Would I be better taking the wires out to the rear trunk and connecting them at the brake light socket there? After searching in the forum, I found several reports of fitting 3rd. brake lights that all were done by wiring to the rear light terminals. Thanks! |
r_towle |
Aug 14 2009, 07:03 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
For some reason I recall that some of the witing for the rear lights goes through the relay board...
This is coming from the single filament bulb in the wrong socket will keep the car running (a Dave Dyer thing) So, I would say run wires from the trunk Rich |
jjbunn |
Aug 15 2009, 11:36 AM
For some reason I recall that some of the witing for the rear lights goes through the relay board... This is coming from the single filament bulb in the wrong socket will keep the car running (a Dave Dyer thing) So, I would say run wires from the trunk Rich OK Rich, thanks ... I guess I need to study the wiring diagram (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 06:10 AM |
