relay board input/output plugs |
Scott S |
Aug 21 2009, 05:14 PM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi all -
I am planning my wiring for the conversion. I will be pulling the relay board. Does anyone make a plug that goes into the factory -4 main harness plug (I dont know if it would be a male of female). I would like to keep the main harness intact, and simply build the other side with the matching wire colors and plug the sucker in - Thanks! (IMG:style_emoticons/default/beerchug.gif) .... |
SirAndy |
Aug 21 2009, 05:27 PM
Resident German Group: Admin Posts: 41,671 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Hi all - I am planning my wiring for the conversion. I will be pulling the relay board. Does anyone make a plug that goes into the factory -4 main harness plug (I dont know if it would be a male of female). I would like to keep the main harness intact, and simply build the other side with the matching wire colors and plug the sucker in My engine conversion harness from Patrick Motorsports had a connector on it that perfectly fit on the stock /4 connector that usually pugs into the relay board. So yes, they are out there ... (IMG:style_emoticons/default/shades.gif) Andy |
Scott S |
Aug 21 2009, 05:44 PM
THANKS!!!!!!!!!!
(IMG:style_emoticons/default/pray.gif) |
ClayPerrine |
Aug 21 2009, 05:54 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The 14 pin male connector is the one you need to fit the 14 pin female connector for the relay board. You can get them from Porsche direct, or do what I did, and call Dennis at Zims. They keep them in stock.
Lo-Fi Version | Time is now: 3rd June 2024 - 11:43 PM |
