> cold start, whats up with this
oldschool
post Aug 30 2009, 12:32 AM
So when ever I first start my car I just can't seem to just get-up and go (IMG:style_emoticons/default/driving.gif)
it dos not like to run cold,it seem to take a long time to get it to run right?
after a slow drive down the street then it work OK.
What should I be looking at,(to fix it) or any pointers.
Replies(1 - 13)
type47
post Aug 30 2009, 08:16 AM
Viermeister
Do you have carbs or fuel injection? If you have carbs, maybe you don't have chokes which enrichen the mixture until warm.
oldschool
post Aug 30 2009, 08:10 PM
QUOTE(type47 @ Aug 30 2009, 07:16 AM) *
stock 1973 1.7 fi
oldschool
post Sep 1 2009, 01:10 AM
QUOTE(oldschool @ Aug 30 2009, 07:10 PM) *
stock 1973 1.7 fi
any love? any one out there in 914 country ? is it just me with this problem?
black73
post Sep 2 2009, 06:56 PM
Mine does the same thing. It also idles very slow until it warms up.
Don't know the solution. (IMG:style_emoticons/default/confused24.gif)
Rand
post Sep 2 2009, 07:03 PM
Cross Member
Is the AAR working?
@oldschool, are you talking low on power or also slow idle?
oldschool
post Sep 2 2009, 10:44 PM
QUOTE(Rand @ Sep 2 2009, 06:03 PM) *
Is the AAR working?
both, it seems to take a long time to warm up. if I try to push it, it just dos not run right. tell it warms up. so why does it take so long?
tod914
post Sep 3 2009, 01:37 AM
What kind of impact does the thermostat have on warm up?
oldschool
post Sep 3 2009, 03:09 AM
QUOTE(tod914 @ Sep 3 2009, 12:37 AM) *
? what
VaccaRabite
post Sep 3 2009, 08:14 AM
En Garde!
QUOTE(oldschool @ Sep 3 2009, 04:09 AM) *
? what
do you have a thermostat installed to speed up warm up times? I think that was the question asked.
Zach
underthetire
post Sep 3 2009, 09:54 AM
I second the AAR idea. If the head temp sensor sees a cold value, it richens up the mix, but if the AAR is not open to allow extra air it would run poorly. Also , if the AAR is not closing with the heating element you might get a lean condition until the ambient temp gets high enough to close it. You need to get on the brad site and go through his troubleshooting check list.
tod914
post Sep 3 2009, 10:03 AM
Quick test with the AAR, pull the vac. line from it that attaches to the airfilter. Put your thumb over the line and see if you get decent suction.
underthetire
post Sep 3 2009, 10:44 AM
That will tell you if it is open. Won't tell if its closing. If you haven't pulled it and cleaned it out, just do it. Test it on the bench. only takes 15 minutes start to finish.
dlo914
post Sep 4 2009, 03:15 AM
Whatchu' lookin' at?!?!
If ya can't get it running well...try taking it to Mueller Motors in Alhambra. They worked on my previous 914 and are VW/Porsche guys.
- Lo-Fi Version Time is now: 31st July 2025 - 04:14 AM
