casey944 |
Member ![]() ![]() Group: Members Posts: 139 Joined: 10-August 09 From: nova Member No.: 10,654 Region Association: MidAtlantic Region ![]() |
So, I replaced the carpet in my car a month or 2 ago and we have had some steady rain since. Felt my carpet today as I was working in my car and felt that both the driver and pass sides are wet. Not the hump in between, not the seats, not the door panels... just the carpet in the foot wells. Where would you recommend I begin searching for leaks? I bought a superweave cover from Cal Car Covers today in hopes that it will cure 98% of the issue but this still bothers me... any help?
Thanks. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Window seals .............
casey944 |
Are you referring to teh seals that go on either side of the glass? So water doesnt get in teh door? Or are you referring to what surrounds teh glass to teh car.
MDG |
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None ![]() |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,841 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
![]() You need this! ![]() |
Cupomeat |
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region ![]() |
Might be window seals, but you should see the water coming down the glass. Also could be a plugged up drain in the fresh air unit, allowing the water to come through the heat vents.
If the water pools behind the passenger seat, check for holes in your lower firewall in the hell hole area. In my early 914 days, I'd get water in from there, as it ran through the small engine grate over the battery and into the hell hole area, of course, then through the firewall and voila, wet interior. |
1970 Neun vierzehn |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 ![]() |
Is your floor pan solid? You don't want to see this on the bottom.....
Attached thumbnail(s) ![]() |
casey944 |
casey944 |
SLITS |
Also could be a plugged up drain in the fresh air unit, allowing the water to come through the heat vents. Can you explain to me where to look for this? Casey Behind the gas tank ..... drain from each side, joins one down pipe to bottom of car. |
balljoint |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,001 Joined: 6-April 04 Member No.: 1,897 Region Association: None ![]() |
Do you have a V8 or other high HP power-plant?
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Once upon a time, I also fixed this same 'mystery' issue by correctly seating the windshield washer squirters. The previous person hadn't gotten them installed all the way down, so water was getting in.
The fresh air unit is the grill in front of the windshield. If the drains are plugged with leaves,etc then the box can fill up and leak water into the cabin. You can use a hose to simulate rain and then crawl around the car looking for drips. That's how I found out about the squirters leaking. |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
The question should be where does a 914 not leak at ? (IMG:style_emoticons/default/piratenanner.gif)
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
Wiper seals might do this , but most of these components are in the front compartment , just exactly where are the carpets getting wet ?? All over , driver's side , passenger side , under the seats , foot by the pedals , on the door silss and the adjacent long area ??
I know some will cringe when I say this , in years past some of the old cars I could afford when I was a kid , some would leak from who knows where , I would take a scratch awl and punch a small hole in a few spots to drain the water out , thereby eliminating carpets staying wet , allowing them to drain and dry out. I know this may be a harsh idea , but until you find and stop the leak , you do want to get the water out and not let it sit on the pan starting rust to form , once the =leake is repaired / remedied, you can / or have some one to weldup the small holes left by the scratch awl. AND yes it sounds like a real crazy idea (IMG:style_emoticons/default/screwy.gif) , to punch holes into floor pans that as a 914 owners we are trying to eliminate. Good luck... Jaxdream |
MDG |
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
[quote name='casey944' Where would you recommend I begin searching for leaks?
Thanks. [/quote] every seal around the removable top!!........especially the front half! (IMG:style_emoticons/default/idea.gif) |
gtp914 |
Newbie ![]() Group: Members Posts: 2 Joined: 2-September 09 From: belgium Member No.: 10,754 Region Association: None ![]() |
Might be window seals, but you should see the water coming down the glass. Agreed. Except for the rear window; it leaks at the bottom and disappears behind the backpad only to reappear as soggy carpet. This leak also helps destroy the firewall and inner longs Have the same problem with my 914 in Belgium... Should use an ordinairy librificant sealkit to prevent water from entering behind the backpad in the passengerscompartiment... Gonna do it tomorrow with acidfree sealkit. Please keep me informed if I should overlook something. Thx |
gtp914 |
MDG |
Window seals ............. what he said. make sure you check the seal around the rear window too; the water runs down behind the backpad and oozes throughout the carpet. Wich window seal??? check the side Targa seals - the ones your windows roll up into. They get old and deformed letting water seep through. Also make sure the front targa seals above the windshield are not damaged and that the clamps holding the roof tight are still okay. |
Lo-Fi Version | Time is now: 31st July 2025 - 09:45 AM |
