WTB or Trade: Fuel tank return line nipple, I have one modified for carbs that I could trade... |
ConeDodger |
Sep 9 2009, 05:31 PM
Apex killer! Group: Members Posts: 23,606 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I am going back to fuel injection. I had previously had Dellortos on my 2270 and will now be going to ITB and aftermarket SDS injection.
Because I can'f find my return line nipple that I saved for just this occasion, I have to tap on you guys. Got one? Going to carbs and want a modified one in trade? The one I have on the tank is brazed and epoxied to seal it so you can use the single feed to the carbs without a return. Need one? |
914Sixer |
Sep 9 2009, 05:58 PM
914 Guru Group: Members Posts: 8,898 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
How many do you want? Send me your address and I will send you one. Do you need the nut also? Small nipple correct?
jcd914 |
Sep 9 2009, 06:48 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Rob,
I have some at the house, I can bring one by. Is your tank and early or late tank? Jim |
ConeDodger |
Sep 9 2009, 06:54 PM
Mark,
Jim lives 8 blocks away and I am actually putting his motor into my car. Thanks for the offer, but I will have to go with convenience over speed this time. Jim, I don't know. I need the return which is the smaller of the two. I didn't know there was a difference on the bottom of the tank. By the way, an update: I ran into two obstacles. One, I was bleeding brakes and Nicho had to leave with Shirley. Two, I cannot hook up the tank yet. I have to get the nipple and some fuel line. I also want to bleed the brakes before putting that tank back in to make sure I don't have a line leak in the front. I have a new, solid steering coupler that goes in while the tank is out as well. What I do have done is this: Everything except the throttle cable is hooked up. I need a barrel bolt or something to hook up the throttle cable. It turns over and you can hear the fuel pump dry pumping... |
914Sixer |
Sep 9 2009, 07:23 PM
Okay. If you need something else let me know. I am starting to clean out 25 yrs worth of parts. My wife seem to think we need to move in the next year.
jcd914 |
Sep 9 2009, 08:30 PM
Rob,
I just got home. I have some barrel nuts just not sure where they are. I'll look around and give you a call. Jim PS: I think all the return line fittings are the same. The feed line on an early tank is larger diameter that late tanks. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:52 PM |
