| skiking |
Sep 16 2009, 09:28 PM
Newbie ![]() Group: Members Posts: 23 Joined: 15-September 09 From: Rapid City Member No.: 10,811 Region Association: None |
I recently had the brake calipers and lines replaced on my '75 teener. When I got it back from the shop, the brake warning flasher light was on all the time. The shop said they tried to fix it, but i'm not sure they knew what they were doing.
The pedal feels a little soft, but the brakes work and the reservoir is full. Any ideas what could be causing the brake warning light to flash whenever the car is running? Thanks, Robbie |
| zx-niner |
Sep 16 2009, 10:10 PM
Member ![]() ![]() Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California |
I recently had the brake calipers and lines replaced on my '75 teener. When I got it back from the shop, the brake warning flasher light was on all the time. The shop said they tried to fix it, but i'm not sure they knew what they were doing. The pedal feels a little soft, but the brakes work and the reservoir is full. Any ideas what could be causing the brake warning light to flash whenever the car is running? Thanks, Robbie Believe it or not, there is a re-set switch on the master cylinder that must be pushed to reset any time you do something like this to the brake system. It catches all of us the first time it happens. Except for me, I got caught twice because my memory is bad. |
| Rod |
Sep 17 2009, 06:32 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
I recently had the brake calipers and lines replaced on my '75 teener. When I got it back from the shop, the brake warning flasher light was on all the time. The shop said they tried to fix it, but i'm not sure they knew what they were doing. The pedal feels a little soft, but the brakes work and the reservoir is full. Any ideas what could be causing the brake warning light to flash whenever the car is running? Thanks, Robbie Believe it or not, there is a re-set switch on the master cylinder that must be pushed to reset any time you do something like this to the brake system. It catches all of us the first time it happens. Except for me, I got caught twice because my memory is bad. Never knew that! |
| flat4 |
Sep 17 2009, 07:04 AM
Member ![]() ![]() Group: Members Posts: 120 Joined: 13-December 07 From: Australia Member No.: 8,459 |
Believe it or not, there is a re-set switch on the master cylinder that must be pushed to reset any time you do something like this to the brake system. It catches all of us the first time it happens. Except for me, I got caught twice because my memory is bad. Never knew that! Apparently it is true. But mine doesn't have one and the dam light doesn't go off. Which is probably why the PO had just cut the wires that went to the MC... Cheers, Steve |
| marks914 |
Sep 17 2009, 02:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Push your e-brake handle all the way down.
Mark |
| bdstone914 |
Sep 17 2009, 02:10 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,206 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If your master cylinder does not have a reset on the outside, you need to pull the switch out of the master cylinder and there will be a button on the inside of the switch for you to press to reset it.
| jt914-6 |
Sep 17 2009, 05:52 PM
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Believe it or not, there is a re-set switch on the master cylinder that must be pushed to reset any time you do something like this to the brake system. It catches all of us the first time it happens. Except for me, I got caught twice because my memory is bad. Never knew that! Apparently it is true. But mine doesn't have one and the dam light doesn't go off. Which is probably why the PO had just cut the wires that went to the MC... Cheers, Steve If you can find the switch wires, the brown/yellow stripe connects to the single connector terminal. The brown attaches to nothing. On switches with two teminals, both connect to it. The single MC switch should have a reset button. |
| jsayre914 |
Sep 17 2009, 06:15 PM
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Push your e-brake handle all the way down. Mark (IMG:style_emoticons/default/agree.gif) I also had this problem due to a loose wires on the little button under the e-brake handle. remove the seat and find the little switch. it sometimes gets wet and malfunctiony" sp. |
| flat4 |
Sep 17 2009, 06:31 PM
If your master cylinder does not have a reset on the outside, you need to pull the switch out of the master cylinder and there will be a button on the inside of the switch for you to press to reset it. (IMG:style_emoticons/default/unsure.gif) Will the fluid leak out, or more importantly air get in, when I do this? Cheers, Steve |
| mpoffers |
Feb 6 2010, 01:42 PM
Member ![]() ![]() Group: Members Posts: 52 Joined: 15-September 08 From: Portland, OR Member No.: 9,551 Region Association: Pacific Northwest |
I'm in the same boat. Single brown wire, no reset button. The switch itself threads into the MC. Can I just take it out? I'd rather not do something stupid and spend the rest of the afternoon bleeding all 4 corners. Thanks, Mike If your master cylinder does not have a reset on the outside, you need to pull the switch out of the master cylinder and there will be a button on the inside of the switch for you to press to reset it. (IMG:style_emoticons/default/unsure.gif) Will the fluid leak out, or more importantly air get in, when I do this? Cheers, Steve |
| skiking |
May 31 2010, 06:28 PM
I recently had the brake calipers and lines replaced on my '75 teener. When I got it back from the shop, the brake warning flasher light was on all the time. The shop said they tried to fix it, but i'm not sure they knew what they were doing. The pedal feels a little soft, but the brakes work and the reservoir is full. Any ideas what could be causing the brake warning light to flash whenever the car is running? Thanks, Robbie Believe it or not, there is a re-set switch on the master cylinder that must be pushed to reset any time you do something like this to the brake system. It catches all of us the first time it happens. Except for me, I got caught twice because my memory is bad. I finally uncovered the master cylinder, and the switch has one terminal on it. Do I need to pull it out to reset? If so, will brake fluid come out? Thanks, Robbie |
| skiking |
May 31 2010, 06:31 PM
If your master cylinder does not have a reset on the outside, you need to pull the switch out of the master cylinder and there will be a button on the inside of the switch for you to press to reset it. Master cylinder now uncovered. Will the brake fluid come out of the master cylinder when I pull the switch out? Thanks, Robbie |
Lo-Fi Version | Time is now: 7th December 2025 - 03:50 AM |
