| westgl |
Sep 18 2009, 08:14 PM
Newbie ![]() Group: Members Posts: 41 Joined: 14-November 08 From: Rogue River, OR Member No.: 9,756 Region Association: None |
Hello,
I am doing a 2004 Subie 2.5 NA engine install into my 1974 914. Anyone use a different fuel pump, other than, stock. My stock fuel pump (Porche fuel pump was missing as was the engine) What should I be looking for to match the needs of the subie FI engine. Thanks Westgl |
| Brujo65 |
Sep 18 2009, 09:42 PM
Newbie ![]() Group: Members Posts: 9 Joined: 23-January 08 From: usa Member No.: 8,613 |
Hello, I am doing a 2004 Subie 2.5 NA engine install into my 1974 914. Anyone use a different fuel pump, other than, stock. My stock fuel pump (Porche fuel pump was missing as was the engine) What should I be looking for to match the needs of the subie FI engine. Thanks Westgl ck with outfront motorsports they have the pump you need |
| VOX |
Sep 18 2009, 09:43 PM
Member ![]() ![]() Group: Members Posts: 129 Joined: 6-February 09 From: rosemead, ca Member No.: 10,027 Region Association: None |
wondering the same thing, i'm hoping for a cheap alternative. im running an ej22 NA. my fuel pump although i have the one from the car, im not sure if its still running and if it will provide the appropriate fuel pressure.
| plymouth37 |
Sep 18 2009, 09:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest
I am running a 928 fuel pump but I am also running a turbo. Not sure if it would be appropriate for an N/A engine.
| BIGKAT_83 |
Sep 19 2009, 04:51 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,800 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States
The stock subaru intank pump will fit with just a little work. The fuel level sender is even close to what the stock 914 vdo gauge needs. About as cheap as they get came with my donor car.
| DBCooper |
Sep 19 2009, 04:52 AM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
I use a generic Walbro 255 lph mounted on the lower front of the engine compartment. Simple, no drama.
| pktzygt |
Sep 21 2009, 05:56 PM
Member ![]() ![]() Group: Members Posts: 328 Joined: 20-March 07 From: Chesapeake, VA Member No.: 7,611 Region Association: MidAtlantic Region |
I bought the pierburg pump from Outfront and decided to use the stock suby setup in the pic above. I bought the suby sized fuel lines from tangerine and decided the suby fuel pump matched the hose size better without renegades complicated solution.
I haven't done any of this yet (broken foot and no garage) except the fuel lines. Still kinda nervous about cutting on the fuel tank. I'll probably do the eastwood fuel tank preservative kit and then cut it when I get my garage next month. |
| sechszylinder |
Aug 27 2024, 07:34 AM
Member ![]() ![]() Group: Members Posts: 271 Joined: 9-April 03 From: /earth/europe/germany/berlin Member No.: 545 Region Association: None
The stock subaru intank pump will fit with just a little work. The fuel level sender is even close to what the stock 914 vdo gauge needs. About as cheap as they get came with my donor car. ![]() Even though the post is a bit older, may I ask which car the fuel pump assembly comes from? br Benno |
| bdstone914 |
Aug 27 2024, 08:01 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@sechszylinder
I have a 1998 Subaru Legacy Outback and the fuel pump assembly looks much like that one. A problem I see is that the 914 tank is much taller than the Subaru tank so the fuel sender would read empty before the tank was near empty. @76-914 |
| East coaster |
Aug 27 2024, 08:32 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,923 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None
| 76-914 |
Aug 27 2024, 08:41 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
When I copied Bob's set up I retained the OEM sender so I could depend on the fuel gauge reading correctly. If you go this route you need to be sure that the pump is located in the well.
![]() ![]() ![]() I have since changed to an external pump configuration. ![]() ![]() The external pump is a Walbro from Amazon. https://www.amazon.com/dp/B07ZSBT6JB?psc=1&...product_details |
| rhodyguy |
Aug 27 2024, 09:00 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
$50 clams? Such a deal.
| Literati914 |
Aug 27 2024, 09:32 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,221 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
.. Even though the post is a bit older, may I ask which car the fuel pump assembly comes from? Benno (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 13th March 2026 - 11:55 PM |
