WTB =L-Jet Decel air valve 1.8, 1975 #022133551a Bosch still need |
914runnow |
Sep 18 2009, 11:31 PM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
Used in great cond. or new desired..
this is a new post..but pics can be seen. on the other prior request for the 2.0 Vdub.. Thanks Rx |
davesprinkle |
Sep 19 2009, 02:12 AM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Used in great cond. or new desired.. this is a new post..but pics can be seen. on the other prior request for the 2.0 Vdub.. Thanks Rx I don't mean to second-guess your reasons for installing the deccel valve, but you're aware that it doesn't really have an effect on the way the engine runs, right? If you're missing the valve, just plug the vacuum lines. |
type47 |
Sep 19 2009, 08:40 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
I'm the other poster looking for the same part. I see a connection between the decel and the fuel pressure regulator so I wonder if it really is needed after all.
zonedoubt |
Sep 19 2009, 09:47 AM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
It depends on how you want the engine to behave during deceleration. I like the "feel" with the decel valve installed.
Plus if you have to emissions test your car, it could have an effect on the readings. |
davesprinkle |
Sep 19 2009, 10:20 AM
I'm the other poster looking for the same part. I see a connection between the decel and the fuel pressure regulator so I wonder if it really is needed after all. Yeah, they might be connected to the same vacuum line tee fitting, but their functions are not related. You can delete the deccel valve; just make sure that the fuel pressure reg still has a manifold pressure reference line. |
davesprinkle |
Sep 19 2009, 10:21 AM
It depends on how you want the engine to behave during deceleration. I like the "feel" with the decel valve installed. Plus if you have to emissions test your car, it could have an effect on the readings. I tried my car with and without the deccel valve. Didn't perceive a difference. (Maybe mine is bad?) And you're right, the deccel valve should probably be in place for an emissions check. |
914runnow |
Sep 20 2009, 09:46 PM
Used in great cond. or new desired.. this is a new post..but pics can be seen. on the other prior request for the 2.0 Vdub.. Thanks Rx I don't mean to second-guess your reasons for installing the deccel valve, but you're aware that it doesn't really have an effect on the way the engine runs, right? If you're missing the valve, just plug the vacuum lines. Concour.....CW Stuff .. Thanx on the info.. |
914runnow |
Sep 25 2009, 05:28 PM
Used in great cond. or new desired.. this is a new post..but pics can be seen. on the other prior request for the 2.0 Vdub.. Thanks Rx I don't mean to second-guess your reasons for installing the deccel valve, but you're aware that it doesn't really have an effect on the way the engine runs, right? If you're missing the valve, just plug the vacuum lines. Concour.....CW Stuff .. Thanx on the info.. (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/confused24.gif) Still Looking.... |
rymann |
Sep 25 2009, 05:34 PM
Newbie Group: Members Posts: 13 Joined: 22-March 09 From: so cal Member No.: 10,191 Region Association: None |
I also think that alot of that is climate and altitude related........
and i may have it as well...hit me with the part # and ill check..... |
Lo-Fi Version | Time is now: 11th June 2024 - 01:32 AM |
