Rear Defog, Where does switch go?? |
Ian Stott |
Sep 19 2009, 10:58 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
I have a 73 2.0 that was originally from California, I also have from my parts car a rear window with the defroster wires. Where would the switch go and where would I get it?
Ian Stott Moncton Canada |
Gustl |
Sep 19 2009, 11:54 AM
914 enthusiast & historian Group: Members Posts: 11,526 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
the switch's origin location is on the right side of the steering column, between the cigarette lighter and the blower control
see the pic Attached image(s) |
914Sixer |
Sep 19 2009, 04:07 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You might want to see if the window grid is any good. Take a volt/ohm meter and put each one of the leads on the clips. You should see a direct short or 0 ohms. Anything else means the grid is open and will not heat. Most grids are open. Not sure if you can get the paint anymore to repair grids as the wires are now embeded in the glass.
tod914 |
Sep 19 2009, 04:32 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Ian could i trouble you to post a shot of the wires? I'm thinking about doing that myself.
Thanks, Tod |
Ian Stott |
Sep 19 2009, 05:23 PM
Thanks for posting the pic of where the switch goes. Tod I will post a pic when I can, the window is not here and I am not doing the swap until the winter. Still having fun driving the car around right now! It was a brisk day today probably around 10 degrees C. cool enough to wear a light jacket but it was clear and I never had to put the roof on, red cheeks but happy smile after about a 60 mile drive. I have a brother in Matawan, would be happy to meet for a beer or coffee sometime when I am down that way with my 914.
MDG |
Sep 19 2009, 08:05 PM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
Here you go Ian, factory location on my '73 2.0
shoguneagle |
Sep 20 2009, 03:23 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
I think I have a switch in the Porsche Junk Pile (i mean in the excellent parts pile) that you can have. Just give some time to locate since I am in the final stages of my 914 project. If I can find it you can have since it just collect space. Once I locate it I will try to verify that the switch is good.
Steve Hurt |
tod914 |
Sep 20 2009, 05:20 PM
Left of the cig lighter is rear fog light then?
MDG |
Sep 20 2009, 06:41 PM
Left of the cig lighter is rear fog light then? I assume Tod is refering to the -6 in the first photo - I was wondering what that green thing was too (IMG:style_emoticons/default/confused24.gif) |
Gustl |
Sep 20 2009, 11:04 PM
I assume Tod is refering to the -6 in the first photo - I was wondering what that green thing was too (IMG:style_emoticons/default/confused24.gif) I really don't know (IMG:style_emoticons/default/confused24.gif) ... but it's not factory original (IMG:style_emoticons/default/biggrin.gif) |
tod914 |
Sep 21 2009, 12:03 AM
Wolfgang, I meant what is suppose to go in that particular hole? Would that be the spot if the rear fog was installed or is it just a spare location?
Gustl |
Sep 21 2009, 01:08 PM
I don't know, if there was an original hole in the dash board
possibly the owner drilled it to install that obscure reen switch I didn't find out what this switch was for - but definitly not for the rear fog light my price lists show that the rear fog light wasn't an option with istalled front fogs so, I guess, that the rear fog light used the same switch as the front fog lights when istalled (IMG:style_emoticons/default/bye1.gif) Gustl |
Ian Stott |
Sep 22 2009, 07:12 AM
Thanks Steve for offering the switch, look forward to getting it. If you have a list of things you need I have some parts and would be glad to help you out. You can contact me by e-mail if that is convenient for you.
ME733 |
Sep 22 2009, 07:44 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
I assume Tod is refering to the -6 in the first photo - I was wondering what that green thing was too (IMG:style_emoticons/default/confused24.gif) I really don't know (IMG:style_emoticons/default/confused24.gif) ... but it's not factory original (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/popcorn[1].gif) On my 1973 S...which has O.E.M. fog lights...I have a BLACK toggle switch. The surrounds, and mounting hardware sure look O.E.M. to me and it is In the exact location of the Green , push/ pull switch shown in the photograph. This switch operates my front fog lights.only. I have never even heard of a REAR fog light, which would seem dangerious, and stupid.... as when /if activated it would obscure the rear brake lights from a following car. I cannot believe this would have been a " PORSCHE" option. (IMG:style_emoticons/default/popcorn[1].gif) |
hcdmueller |
Sep 22 2009, 08:25 AM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
The rear fog is required in a lot of European countries. There are rules on how far it will be placed from tail lights and on which side of the car. It makes a car much more visible from behind. Ask the Brits. They need them the most. If I go back to England I will put one on my 914.
MDG |
Sep 22 2009, 08:38 AM
(IMG:style_emoticons/default/popcorn[1].gif) On my 1973 S...which has O.E.M. fog lights...I have a BLACK toggle switch. The surrounds, and mounting hardware sure look O.E.M. to me and it is In the exact location of the Green , push/ pull switch shown in the photograph. This switch operates my front fog lights.only. I have never even heard of a REAR fog light, which would seem dangerious, and stupid.... as when /if activated it would obscure the rear brake lights from a following car. I cannot believe this would have been a " PORSCHE" option. (IMG:style_emoticons/default/popcorn[1].gif) The factory placement of the various dash switches didn't really alter. My '73 in the photo (sorry for the state of it - taken during disassembly) has all the options that were available at the time - and the switches that go with them. The green switch on the right operates the rear window defroster; all 914s that came with this option had that switch in that location. The amber switch peeking out on the left side of the steering wheel operates the front fogs; all 914s that came with front fogs came with that switch in that location (the color of the bezel changed through the run). If you have a toggle switch operating your front fogs somebody put it there after the fact as Porsche/VW did not use that location, nor a toggle switch, for the fog lights. It's not impossible that it may have been done at the time by the dealership that sold the car. m. |
shoguneagle |
Sep 24 2009, 07:27 PM
we are currently traveling in California and will be home next week. Will try to locate the part at that time.
Steve Hurt |
Cevan |
Sep 24 2009, 07:46 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Here's my '75:
shoguneagle |
Oct 7 2009, 06:37 AM
We are now back home for a week or so then traveling again. Trying to get as much in before I have to slow down. This retirement is for the "birds".
I will look for the switch in the morning and see what I have. Still want it?/ Just bear with me and I will get it to you. |
shoguneagle |
Dec 1 2009, 01:46 PM
Ian,
Bet you thought I had forgotten about you. FOUND THE REAR DEFROSTER SWITCH FOR YOU!!!! I went through several different storage houses and the garage; could not put my hands on the alusive part. By this time, I am pulling out whatI I finally said I am going to work on the Porsche wiring. Heated up the garage; looked outside at the snow; I wondering if I really wanted to work on the electrical since the garage is such a mess. Anyway, started on the electrical, gauges, and switch area. Second switch I put my hand on was the very alusive rear heater switch. Yes, it is the switch with the three loops inside a rectangle with green background. Sent an email this date. Sorry I took so long in finding the part. Steve Hurt |
Lo-Fi Version | Time is now: 10th June 2024 - 09:49 PM |
