Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
At what altitude points is it necessary to rejet carbs? Will a car coming from the SF Bay Area need to be rejetted in Reno (4500ft)?
Madswede |
Flat Out Driver ![]() ![]() ![]() Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains ![]() |
Anyone go as far as to rejet their carbs for Atomic Ramble 07? If not, and you went on the drive up the Sandias, you made it to 10,400 ft without it (the crest is 10,700 or so, we were just below it).
As I recall, there was quite a bit of coughing and sputtering (until I finally passed Lauren Luckie and SLITS), but people made it up there! - Nelson |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
I had to quit smoking @ 9.5 to keep from sputtering and backfiring.
Sleepin |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains ![]() |
You will (read: should) be able to run the car in Reno. However, if the car is staying there for good, you should probably need to rejet it. It will run a little rich and performance will drop a bit, but you should be ok.
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
When coming from sea level I've always noticed the difference at around 4000 feet. So ideally you'd want to rejet, but as already stated if your only there for 3 days there really isn't much point. Often enough I take mine from 5000 feet to over 10. I notice the difference, but it's always temporary since I head back home in a day or two.
Rand |
Thanks gang. She would live in Reno, so sounds like I should pick up some optimum jets for 4500ft, keep the others on hand for long visits to the coast, and just live with it for the short visits to the higher altitudes.
(IMG:style_emoticons/default/beerchug.gif) |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
For what it's worth (probly not much) my car ran really rich at sea level. I used to get about 18 miles per gallon with my 2.2 type four with weber carbs. I took it up to Sandia Peak 10,400 feet and the plugs would load up till I kept the revs up and it ran kinda rough but it ran ok enough to get up there and back. I re-jetted since then and I get 25mpg at sea level now, so I think it will be fine in Tahoe.
Lo-Fi Version | Time is now: 1st July 2025 - 03:40 AM |
