| hot_shoe914 |
Sep 30 2009, 10:56 PM
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Drivers side of car on 2.0 injection. Can anybody tell me what this plugs into?
| jcd914 |
Sep 30 2009, 10:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Relay panel in the engine compartment.
Jim |
| hot_shoe914 |
Sep 30 2009, 11:06 PM
| srb7f |
Sep 30 2009, 11:24 PM
Member ![]() ![]() Group: Members Posts: 157 Joined: 17-May 04 From: Roswell, GA Member No.: 2,077 Region Association: None |
black plastic covering, sits behind the driver in the engine compartment.
| hot_shoe914 |
Sep 30 2009, 11:25 PM
| JeffBowlsby |
Oct 1 2009, 12:59 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,390 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
| tod914 |
Oct 1 2009, 01:48 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
The grey injector boot faces the rear of the car.
| jk76.914 |
Oct 1 2009, 04:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
It's going to be tricky getting that setup into the car. You have straight injector hoses, not elbow hoses, plus your steel tube fuel manifold ends are pointing down. Not sure if the straight hoses will work at all, but if they do, you might be better off installing the injectors after the engine goes in.
| JeffBowlsby |
Oct 1 2009, 09:58 AM
| SLITS |
Oct 1 2009, 10:37 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Straight hoses work if you make them long enough to not kink. The fuel rail may sit against the body. Saves buying those prebent little hoses at an exhorbitant price, but then, I'm not a CWQ.
| tod914 |
Oct 1 2009, 11:43 AM
Jeff guess mine are swapped (or one was anyway, glad you chimed in Jeff). I just dug up some old photos of some other cars, and yes you are correct!
Cheaper elbows for you. Jeff did you ever pick these up and confirm the ID size? http://www.914world.com/bbs2/index.php?sho...p;hl=bmw++elbow "This is from my invoice when I bought the elbows in early '08: BMW part # is 16-12-1-176-821. Description is 7043E Hose Price was $3.06 each at that time. Paul " |
| JeffBowlsby |
Oct 1 2009, 02:38 PM
I ended up sourcing the OEM elbows :shame:
But I did include several substitute elbow part numbers on the substitute parts list on my webpage here: http://bowlsby.net/914/Classic/TechNotebook.htm |
Lo-Fi Version | Time is now: 19th November 2026 - 10:57 PM |
