FS: Heat Exchangers in Excellent condition |
RiqueMar |
Oct 1 2009, 12:02 AM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Sandblasted and cleaned. Came with the car but I'm changed motors. Never used.
$200 OBO. Plus shipping. (IMG:http://i16.photobucket.com/albums/b6/Emar06/d1a043b5.jpg) (IMG:http://i16.photobucket.com/albums/b6/Emar06/efb986c6.jpg) |
Tom_T |
Oct 1 2009, 12:37 AM
From which engine size?
...stainless steel or OE stock mild steel?? (IMG:style_emoticons/default/confused24.gif) |
tat2dphreak |
Oct 1 2009, 09:04 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
they bolt up to any -4. but I believe these will need a 1.7/1.8 Muffler... the 2.0 version is straight at the end.
if they are SS they will have the same Inter-Diameter pipes, regardless. |
RiqueMar |
Oct 1 2009, 10:51 AM
Tom_T |
Oct 1 2009, 02:32 PM
they bolt up to any -4. but I believe these will need a 1.7/1.8 Muffler... the 2.0 version is straight at the end. if they are SS they will have the same Inter-Diameter pipes, regardless. btw - I believe that the 2.0s are a bit larger diameter pipes, ergo better exhaust flow. Thanx for the clarification & Rique too! |
tat2dphreak |
Oct 1 2009, 03:14 PM
they bolt up to any -4. but I believe these will need a 1.7/1.8 Muffler... the 2.0 version is straight at the end. if they are SS they will have the same Inter-Diameter pipes, regardless. btw - I believe that the 2.0s are a bit larger diameter pipes, ergo better exhaust flow. Thanx for the clarification & Rique too! not in stainless... the SS is the same. stock mild steel is larger in 2.0 |
Gint |
Oct 1 2009, 08:02 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Sandblasted and cleaned. Came with the car but I'm changed motors. Never used. By "never used" I'm pretty sure you mean since they were blasted and cleaned up right? Because they look like used stock 1.7/8 heat exchangers. You never said for sure and there are some that might not know. So I just wanted to clarify. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:13 PM |
