| kenshapiro2002 |
Oct 2 2009, 08:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,469 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Too easy for a joke. Anyway, I was starting to rebuild my lock mechanism on the drivers door and tore up the rear window guide cap. I went to order one (anybody got a good used one?) and noticed they differ for up to, and after 1973 (My car is a 1970). I then noticed that my two end caps (right vs. left) are different. Not sure whether I need an ear;y or later version for my driver's door. Since the driver's door has been replaced, I'm guessing it's the later model, but you never can tell. Is there some way to tell whether the driver's door, and therefore it's end cap, is early or late? The driver's door end cap (the one I destroyed) has a rounder slot for the window thatn the passenger side one which is more angular looking.
| URY914 |
Oct 2 2009, 09:03 AM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 129,967 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Match.com
| Ferg |
Oct 2 2009, 09:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None
Later doors have a inner brace... early doors do not.
| Cupomeat |
Oct 2 2009, 11:04 AM
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Also, it is my understanding that the early doors have the guide chain style window riser, where the later doors have the scissor style.
| ghuff |
Oct 2 2009, 11:10 AM
This is certainly not what I expected down here. ![]() ![]() ![]() Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
My 1975 has scissor style window lifts in each door if that helps any Ken.
| ghuff |
| TROJANMAN |
Oct 2 2009, 11:45 AM
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,275 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Just try and pick up it up. If you can't, then you have a later door (IMG:style_emoticons/default/laugh.gif)
(IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) Attached image(s)
| kenshapiro2002 |
Oct 2 2009, 12:45 PM
| r_towle |
Oct 2 2009, 01:00 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Early doors, up to the middle of 1972 have no door braces.
the door braces look like three tubes welded to the inner door skin running horizontal. The early door window mechanism is a cable style that runs inside a metal tube, the later style is a scissor style. Early doors have all different window rubber, including the fuzzy strips and end caps. Pull the door panels, you may have one of each door...who knows. AA has both early and late door parts. Rich |
| kenshapiro2002 |
Oct 2 2009, 01:03 PM
So...seems I have a late door on my '70, right?
| r_towle |
Oct 2 2009, 01:04 PM
That is a later door, yes.
Two positive points. Door bars will save you life. Window mechanism is WAY better. Rich |
| kenshapiro2002 |
Oct 2 2009, 01:15 PM
Alright...I need a rear window guide cap for a later model driver's door. Anybody got one lying around?
| r_towle |
Oct 2 2009, 01:16 PM
AA has a boatload of new ones...get new
| Cupomeat |
Oct 2 2009, 02:03 PM
I agree, the old ones crack when brittle.
I also think that having the later doors is worth the weight, unless you are racing the car. |
| ClayPerrine |
Oct 2 2009, 09:51 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
One correction....
Euro 73 doors do not have the door bar, but have the late model window mechanism. I know. I have one. (Parted out a euro 73 years ago). |
| EyeTrip |
Oct 2 2009, 10:09 PM
Member ![]() ![]() Group: Members Posts: 104 Joined: 29-May 07 From: Camas, Wa Member No.: 7,767 Region Association: None |
one more correction ... the rubber is the same
| EyeTrip |
Oct 2 2009, 10:12 PM
I have one early and one late 72 doors ... I agree with the weight and the window reg smoothness. And yes ... they are different.
| kenshapiro2002 |
Oct 3 2009, 10:05 AM
Lo-Fi Version | Time is now: 8th December 2025 - 06:03 PM |
