astronomerdave |
Member ![]() ![]() Group: Members Posts: 69 Joined: 26-January 09 From: Los Angeles, CA Member No.: 9,979 Region Association: Southern California ![]() |
I don't have a center console but am considering getting one for the sole purpose of a place to mount some custom gauges. So, not having one, I don't know how much space I have. Can someone give me the dimensions of the visible area of the front panel on a center console?
I was thinking I could also use a deposit box since I have to make my front panel anyway (and place my panel across the front of the DB). Thanks, D |
Rod |
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England ![]() |
I don't have a centre console, and love the 914 interior without it - what gauges do you want to add?
astronomerdave |
I don't have a centre console, and love the 914 interior without it - what gauges do you want to add? I want to add this gauge: EVision which I know will fit. But I also want to add one of these touchscreen displays: EBY701 which I am not sure will fit. There is a DIN frame available (DIN) for mounting the touch screen. The VGA touch screen is for my on-board computer which I can use to display information and tweak parameters of the car's controller -- it's an electric car (IMG:style_emoticons/default/biggrin.gif) |
Rod |
Ah Ok so a double din fitment. In which case a centre console will probably be the only way to go - unless you rebuild the dash and move the heater controls and the ashtray. (I was toying with the idea of a double din unit there, but I went for two din units side by side and deleted the glovebox..
The first gauge could easily be built in below this, or my preference in the dash in the place of the cigar lighter. (How deep is the control unit? btw, could it not be mounted to slide up/out of the dash? |
flipb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,820 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region ![]() ![]() |
The face of my original console ('74) measures 11 3/4" x 5 7/8".
Lo-Fi Version | Time is now: 31st July 2025 - 11:24 AM |
