Fuel Tank Filler, How to modify to accept gas pump nozzle? |
nick mironov |
Oct 3 2009, 04:11 PM
nickm Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 |
The modern gas pump nozzle has a larger diameter at the far end that keeps the nozzle from going all the way into the tank filler opening, and the fuel vapor recovery accordion cover can not retract. I have to manually retract the mechanism when I fill up, and it's awkward.
What does it take to modify the the fuel tank filler opening to a larger diameter so that the nozzle fits inside all the way and retracts the vapor recovery accordion cover? Nick |
tod914 |
Oct 3 2009, 04:22 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Your better off doing it manually and holding it in until it's full. They can pop and put a nice dent in your hood.
PanelBilly |
Oct 3 2009, 05:11 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Its been a loooong time since I need to fuel the tank, but I remember putting the cap next to the hole and pressing one side of the accordian sleeve against it so the fuel would pump
MartyYeoman |
Oct 3 2009, 07:52 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Its been a loooong time since I need to fuel the tank, but I remember putting the cap next to the hole and pressing one side of the accordian sleeve against it so the fuel would pump (IMG:style_emoticons/default/agree.gif) That's the trick I use. |
bandjoey |
Oct 3 2009, 09:52 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Mikey914 rubberdonut for the gas filler neck?? (IMG:style_emoticons/default/idea.gif)
pjhaun |
Oct 3 2009, 09:53 PM
Member Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
The modern gas pump nozzle has a larger diameter at the far end that keeps the nozzle from going all the way into the tank filler opening, and the fuel vapor recovery accordion cover can not retract. I have to manually retract the mechanism when I fill up, and it's awkward. What does it take to modify the the fuel tank filler opening to a larger diameter so that the nozzle fits inside all the way and retracts the vapor recovery accordion cover? Nick In the 1970's I bought this clip just for that reason. Here is a picture of the clip. Phillip J. Haun Oak Harbor, Wa. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:00 AM |
