| pete914 |
Feb 22 2008, 05:52 AM
Member ![]() ![]() Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 |
Did a quick search and the only thing that came up was the electrical wiring article which has already been done on the car. Anyway, putting a set of weber idf 40's on my 1.8L. Right now I have a holley single carb on the engine. Do i run two lines ouf the fuel pump?
Anyone know of a good place to read up on this? Thanks much Oh, here's a picture of the carbs. You guys might have seen these in the F/S section. They ended up on eBay. What other parts am I going to need besides the bolts for the manifolds? I will need something for the throttle cable to attached somewhere rigid correct? Does the linkage need anything additional? I've actually never seen one of these on a 'teener in person, so I'm a little confused. (IMG:http://i35.photobucket.com/albums/d189/pba110/914/101_1608.jpg) (IMG:http://i35.photobucket.com/albums/d189/pba110/914/101_1609.jpg) (IMG:http://i35.photobucket.com/albums/d189/pba110/914/101_1610.jpg) |
| purple |
Feb 22 2008, 07:31 AM
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
I had one fuel like coming from the pump. the other is closed off. I have a T fitting that feeds both carbs.
>=FUEL==T=>====>===carb ................ || ................ || ................ || ................ carb ignore the periods, i needed them to overcome the forum's text displaying engine by 'low pressure' pump, SGB means something like a carter (CB) rotary pump. it has an internal regulator that keeps pressure between 3 and 3.5 PSI using a facet or vibrator fuel pump is NOT GOOD! unless you have a regulator, in which case, you've spent as much as a carter costs. in other words, use a carter and a T fitting |
pete914 Converting from single to dual webers Feb 22 2008, 05:52 AM
Spoke If you're already running carbs and your fuel ... Feb 22 2008, 06:24 AM
type47 i'm probably not the one who should answer as ... Feb 22 2008, 06:25 AM
SGB i had a pressure regulator but took it out. it is... Feb 22 2008, 06:54 AM
rhodyguy in direction of flow. tank, filter, pump (single o... Feb 22 2008, 08:59 AM
pete914 Awesome. thanks Everyone. There is a pressure regu... Feb 22 2008, 03:39 PM
type47
yo, type47, how did the installation go?
easy... Feb 23 2008, 01:48 PM
rhodyguy if you're going to use an unregulated fuel pum... Feb 23 2008, 10:30 AM
brer I responded to these when they were first posted.
... Feb 23 2008, 01:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2026 - 03:01 AM |
