| pete914 |
Feb 22 2008, 05:52 AM
Member ![]() ![]() Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 |
Did a quick search and the only thing that came up was the electrical wiring article which has already been done on the car. Anyway, putting a set of weber idf 40's on my 1.8L. Right now I have a holley single carb on the engine. Do i run two lines ouf the fuel pump?
Anyone know of a good place to read up on this? Thanks much Oh, here's a picture of the carbs. You guys might have seen these in the F/S section. They ended up on eBay. What other parts am I going to need besides the bolts for the manifolds? I will need something for the throttle cable to attached somewhere rigid correct? Does the linkage need anything additional? I've actually never seen one of these on a 'teener in person, so I'm a little confused. (IMG:http://i35.photobucket.com/albums/d189/pba110/914/101_1608.jpg) (IMG:http://i35.photobucket.com/albums/d189/pba110/914/101_1609.jpg) (IMG:http://i35.photobucket.com/albums/d189/pba110/914/101_1610.jpg) |
| rhodyguy |
Feb 23 2008, 10:30 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
if you're going to use an unregulated fuel pump, and one of the mystery fp regulators, you'll need to install a GOOD, ACURATE, gauge downstream from the regulator prior to the T. more connections, more hassles. why bother? my guess is the gauge will cost as much as the new pump. once the reg is set the gauge is redundant.
k |
pete914 Converting from single to dual webers Feb 22 2008, 05:52 AM
Spoke If you're already running carbs and your fuel ... Feb 22 2008, 06:24 AM
type47 i'm probably not the one who should answer as ... Feb 22 2008, 06:25 AM
SGB i had a pressure regulator but took it out. it is... Feb 22 2008, 06:54 AM
purple I had one fuel like coming from the pump. the othe... Feb 22 2008, 07:31 AM
rhodyguy in direction of flow. tank, filter, pump (single o... Feb 22 2008, 08:59 AM
pete914 Awesome. thanks Everyone. There is a pressure regu... Feb 22 2008, 03:39 PM
type47
yo, type47, how did the installation go?
easy... Feb 23 2008, 01:48 PM
brer I responded to these when they were first posted.
... Feb 23 2008, 01:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2026 - 03:00 AM |
