> Converting from single to dual webers, how do I go about modifying the fuel pump?
pete914
post Feb 22 2008, 05:52 AM
Did a quick search and the only thing that came up was the electrical wiring article which has already been done on the car. Anyway, putting a set of weber idf 40's on my 1.8L. Right now I have a holley single carb on the engine. Do i run two lines ouf the fuel pump?
Anyone know of a good place to read up on this?
Thanks much
Oh, here's a picture of the carbs. You guys might have seen these in the F/S section. They ended up on eBay. What other parts am I going to need besides the bolts for the manifolds? I will need something for the throttle cable to attached somewhere rigid correct? Does the linkage need anything additional? I've actually never seen one of these on a 'teener in person, so I'm a little confused.
(IMG:http://i35.photobucket.com/albums/d189/pba110/914/101_1608.jpg)
(IMG:http://i35.photobucket.com/albums/d189/pba110/914/101_1609.jpg)
(IMG:http://i35.photobucket.com/albums/d189/pba110/914/101_1610.jpg)
rhodyguy
post Feb 22 2008, 08:59 AM
in direction of flow. tank, filter, pump (single outlet, like the cb unit mentioned), single line to the engine bay, T in bay with the lines branching to the carbs. you'll need to fab up a STOUT bracket to secure the throttle cable.
k
pete914
post Feb 22 2008, 03:39 PM
Awesome. thanks Everyone. There is a pressure regulator after the pump. However, it doesn't have a psi value. Just 1, 2, 3 or something like that. Perhaps that corresponds to psi though.
I'll take a better look when the weather improves. 38 and raining right now. Lovely.
Can't wait for spring!
yo, type47, how did the installation go? I actually ordered an almost complete d-jet setup (seller thought it was L-jet) thinking I was going to restore the FI. Ended up backing off the project though. I think the dual webers are the answer for now...
type47
post Feb 23 2008, 01:48 PM
Viermeister
QUOTE(pete914 @ Feb 22 2008, 01:39 PM) *
easy since i was basically swapping motors. the motor that came in the car in my avatar was a "race" motor with carbs so it had a carb pump and carb pump wiring. i swapped in a d-jet motor so i installed the d-jet with the motor out. had to reinstall the FI pump though.
you going to the ECC?
- Lo-Fi Version Time is now: 23rd October 2026 - 03:39 AM
