| 914pipe |
Feb 14 2008, 09:24 PM
Say......TEEEEEEEN!!!!! ![]() ![]() Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
Hi there:
There was a guy running hard pipes of 3/4" ID.... I use to have a link but doesn't work. Does anyone knows if that configuration ever worked...? Would like to hear from that guy.... I have the opportunity to get 3/4 in ID SS braided hoses.... Thanks..!!! Pics...? |
| marks914 |
Feb 15 2008, 08:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Desert hybrids uses 3/4 black (1 in od) pipe under the car. seems to work fine in arizona.
I have been running 1in copper/aluminum lines under my car for 40,000 miles and 6 years, no problem. I don't understand why copper gets the bad rap. Solder melts at 450F, and the better radiators are made from copper because of copper's superior heat transfer. I could see if you are worried about denting it running something over, but why don't ypu watch where you are going. if you hit your floor pan on something, you probably will hit your engine bar too. Mark |
| vespasoul |
Feb 25 2008, 12:19 AM
Newbie ![]() Group: Members Posts: 10 Joined: 2-April 06 From: las vegas, nv Member No.: 5,809 |
Desert hybrids uses 3/4 black (1 in od) pipe under the car. seems to work fine in arizona. I have been running 1in copper/aluminum lines under my car for 40,000 miles and 6 years, no problem. I don't understand why copper gets the bad rap. yeah and with copper you can install a toilet in the front trunk too the question you should be asking yourself is: am i running cooling lines in an auto??? or running plumbing in a house??? |
nukepipe For the V8 guys... cooling lines. Feb 14 2008, 09:24 PM
wbergtho I have heard of people using 3/4 id hoses...and I... Feb 14 2008, 09:57 PM
Andyrew I believe that was Rick w/ the Alien..
I would g... Feb 14 2008, 10:06 PM
nukepipe Thanks Bill.... any pics from your set up...??
... Feb 14 2008, 10:07 PM
ajracer nukepipe:
Not sure which hard line installation y... Feb 15 2008, 10:10 PM
ajracer Another shot Feb 15 2008, 10:14 PM
nukepipe Thank you very much guys.... this really help... Feb 15 2008, 11:39 PM
jd74914 Water is water . . . Feb 25 2008, 12:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 06:22 PM |
