| r_towle |
Mar 15 2003, 05:24 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
So,
I want to stop shifting so much at the Autocross. What gears would you all recommend??? Rich |
| porsche735 |
Mar 19 2003, 09:24 PM
Member ![]() ![]() Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 |
Rich,
As I said, no gears to buy. All you do is move 3rd to 5th and swap the pinion and drive gears. Flip 4th pinion and drive gears and use the old 5th in the 3rd location swapping the pinion and drive gears. It is really very easy to do. I have a brand new transmission that I have done this to if there are any takers... Chris |
r_towle AX transmission Mar 15 2003, 05:24 PM
ChrisReale Not a professional answer (ill leave that to the "... Mar 15 2003, 06:15 PM
Zeke In that case, Chris, I think you're friend has... Mar 15 2003, 06:42 PM
J P Stein I would like an A or B first. We are pretty much S... Mar 15 2003, 07:57 PM
ChrisReale Zeke, he IS going faster than me, by about ten f... Mar 15 2003, 08:50 PM
J P Stein <... Mar 19 2003, 08:33 PM
Brad Roberts I normally use the terms (Drive and Driven gears) ... Mar 19 2003, 09:35 PM
Brad Roberts Richard,
We flip 5th gear to make a new shorter 3... Mar 19 2003, 10:52 PM
Mike T
drew365 This sounds like a good mod for a short road cours... Mar 20 2003, 09:46 AM
Joseph Mills I've been given two spare trannys from an ex-r... Mar 20 2003, 10:18 AM
Brad Roberts Joseph.
Flip a 5th from the tranny you want to us... Mar 20 2003, 11:08 AM
Brad Roberts Oh,
we chat about this like it is nothing. NONE o... Mar 20 2003, 11:10 AM
James Adams Gear chart for about a stock diameter tire (calcul... Mar 20 2003, 11:19 AM
Zeke
Travis Neff So, for a hot street setup - you would want to obt... Mar 20 2003, 01:19 PM
TimT Brad
I took the liberty to play with the pic yo... Mar 20 2003, 03:58 PM
TimT oops helps to attach the pic Mar 20 2003, 04:03 PM
Zeke I just did this and that's exactly what it loo... Mar 20 2003, 04:31 PM
bpick84 It will run okay in reverse cut, but it may whine ... Mar 21 2003, 09:35 AM
Zeke No one is gonna explain to me what "delta" is (I t... Mar 21 2003, 10:46 AM
Mueller 3.09-1.89=1.2
1.2/3.09=39% differance (delta)
1.8... Mar 21 2003, 11:13 AM
Demick I think the picture in Tim's post above shows ... Mar 21 2003, 12:04 PM
Brad Roberts Bill Pickering ?? If that is you... welcome. Thank... Mar 21 2003, 12:17 PM
r_towle I am close to understanding this...please forgive ... Mar 21 2003, 05:33 PM
TimT
Zeke <... Mar 21 2003, 05:53 PM
Demick Rich
Drive gears are always on the input shaft, d... Mar 21 2003, 06:05 PM
Brad Roberts It wasnt designed for it, but I personally have be... Mar 21 2003, 06:22 PM
TimT I wondered about the thrust issue. Then being an e... Mar 21 2003, 06:38 PM
porsche735 Back to this stock 5th thing.... Why would you wa... Mar 21 2003, 07:08 PM
TimT Milt did you get that spreadsheet I sent your way... Mar 21 2003, 07:24 PM
Racer Chris
Brad Roberts Chris,
The thread started out as a AUTOX thread..... Mar 21 2003, 11:49 PM
TimT Chris, I just bought the GT4 car, havent turned a ... Mar 22 2003, 08:31 AM
Racer Chris
TimT Chris I know your were teasing just wanted to use ... Mar 22 2003, 06:28 PM
mskala This may not apply to many, but for PCA
AX in our ... Mar 22 2003, 06:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:26 AM |
