| Joe Bob |
Feb 21 2008, 09:23 PM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
http://www.electroauto.com/gallery/vp914.shtml
http://electric914.wordpress.com/ http://www.evcl.com/914/ Electro Automotive has a kit for 14K...yikes..... Otmar seems to be REAL busy building components..... I'm thinkng of doing one for my twins..... (IMG:style_emoticons/default/blink.gif) I have two years to get it done..... |
| pjf |
Feb 28 2008, 08:27 PM
Member ![]() ![]() Group: Members Posts: 132 Joined: 27-September 04 From: Ipswich, MA Member No.: 2,840 |
What can I tell you? When I saw $150 each for a 6v battery I called my local "battery guy" and he quoted me $109 and change. This was just a few days ago. It is on the other coast so that may make a difference. I agree that 144v using 12v batteries is not much good. You could blast around the neighborhood but you'd better not go too far. A better idea is using 18 8v batteries. Its supposed to be a compromise between distance and performance.
As far as tuning a controller. If you want simplicity you can go with a Curtis controller that has no programming at all. With the Zilla you have settting to play with but a computer or adapted Palm will do the trick and it doesn't sound that hard. |
| banger |
Feb 29 2008, 07:41 AM
Member ![]() ![]() Group: Members Posts: 354 Joined: 12-November 06 From: Santa Clarita Member No.: 7,205 Region Association: Southern California |
When buying batteries, you must keep in mind that not all batteries are created equal. Most people think that all 6v golf cart batteries will be close to the same. There are wide variances between battery manufactures. Ask for a datasheet on the batteries, and look at the discharge curves for each battery you are considering. Some batteries may have the same Ah capacity, at a 20 hour rate, but when you try to pull 500-1000 amps on them, they are completely different. Some of the cheaper batteries are unable to supply high currents efficiently, and will generate an excess amount of heat.
356 914 EV discussion Feb 21 2008, 09:23 PM
356 http://www.kta-ev.com/catalog/index.html
This see... Feb 21 2008, 09:46 PM
smontanaro Lots of people have done 914 EVs. Here are some l... Feb 21 2008, 10:11 PM
banger It all depends what you are looking to get from a ... Feb 22 2008, 03:05 AM
racunniff
Lots of people have done 914 EVs. Here are some ... Feb 22 2008, 04:43 AM
pjf I'm restoring a '76 914 intending to conve... Feb 22 2008, 08:44 AM
banger You may want to look the the ford ranger ev motor ... Feb 22 2008, 09:23 AM
smontanaro
You may want to look the the ford ranger ev motor... Feb 22 2008, 09:47 AM
banger The inverter is just a siemens Simovert, which can... Feb 22 2008, 10:04 AM
smontanaro Unfortunately it delivers about half the horsepowe... Feb 22 2008, 09:48 AM
356 The Auto Electric "kit" claims 100-150 m... Feb 22 2008, 09:58 AM
neo914-6
The Auto Electric "kit" claims 100-150 ... Feb 25 2008, 03:31 PM
356
The Auto Electric "kit" claims 100-150... Feb 25 2008, 03:48 PM
pjf I have to respectfully disagree with Banger's ... Feb 22 2008, 10:47 AM
356
I have to respectfully disagree with Banger's... Feb 22 2008, 03:09 PM
banger
The 2 types of chargers are either Conductive - A... Feb 22 2008, 07:33 PM
banger The price on Trojan T-105 batteries are around ... Feb 22 2008, 07:23 PM
pjf Looking over my last post I realized I messed up t... Feb 22 2008, 11:15 AM
smontanaro The horsepower rating for an electric motor is als... Feb 22 2008, 12:20 PM
356 Further.....are NiMH or Li batteries available in ... Feb 22 2008, 03:11 PM
geniusanthony I too have been kicking this idea around lately. M... Feb 22 2008, 04:15 PM
neo914-6 You really need a higher no cost goal to go electr... Feb 22 2008, 05:36 PM
Zundfolge I wouldn't be interested in an electric 914 un... Feb 22 2008, 07:00 PM
banger The 914 could be converted into "Tesla" ... Feb 22 2008, 07:27 PM
geniusanthony Wait for the first A-List star to wrap his around ... Feb 22 2008, 07:24 PM
PThompson509 I'm one of the "idiots" doing the co... Feb 23 2008, 12:51 AM
banger I am sure that you probably could get 150 miles on... Feb 23 2008, 04:30 AM
356 And those batteries are available where?????
AND.... Feb 23 2008, 09:50 AM
Mike914
AND... Feb 23 2008, 10:53 AM
356 I'm an instant gratification type of guy....I ... Feb 23 2008, 01:29 PM
banger The BB600 nicad cells are often available governme... Feb 23 2008, 02:30 PM
smontanaro There are a few other vendors out there you might ... Feb 23 2008, 02:30 PM
pjf 356, to answer your question about the parts I... Feb 23 2008, 03:24 PM
pjf About the clutch and shifting, all the 914 convers... Feb 23 2008, 03:30 PM
pjf You also asked about my charging plans. I plan o... Feb 23 2008, 03:41 PM
pjf I also double checked my estimate for the cost per... Feb 23 2008, 04:11 PM
banger Just be careful with your calculations. 550 cycle... Feb 24 2008, 12:50 AM
356 I signed up for the EVDL discussion list....hope i... Feb 23 2008, 07:50 PM
banger Otmars car is built for acceleration, which is why... Feb 24 2008, 12:24 AM
r_towle
I signed up for the EVDL discussion list....hope ... Mar 5 2008, 02:41 PM
daveyboybadion I too have been toying with the idea of an electri... Feb 23 2008, 08:41 PM
banger There are other options as well, if you are just l... Feb 24 2008, 12:05 AM
pjf There is no substitution for real-world experience... Feb 24 2008, 07:52 AM
banger Initially they start out a little low on capacity,... Feb 26 2008, 03:13 PM
356 E85 needs a dedicated engine designed for that fue... Feb 24 2008, 08:34 AM
banger E85 is ethanol, which is a little easier to handle... Feb 26 2008, 03:22 PM
356 http://www1.pressdemocrat.com/apps/pbcs.dl...ctid=... Feb 26 2008, 08:01 PM
Eric_Shea :idea: Wilderness is here in Lehi (no Z... you can... Feb 26 2008, 08:27 PM
356 Looking into what they sell...Wilderness will get ... Feb 26 2008, 08:36 PM
pjf Wilderness does have a low price but if you want p... Feb 27 2008, 07:37 PM
356 Does WarP provide the adapter plate? Feb 27 2008, 08:46 PM
pjf No, you have to get it somewhere else but the WarP... Feb 27 2008, 09:16 PM
356 Sure....
My email is 356@cox.net
I've been cr... Feb 27 2008, 10:16 PM
pjf I sent you an email with the link for the adaptor ... Feb 28 2008, 04:29 PM
356 Thanks for the email....you must be getting good p... Feb 28 2008, 05:10 PM
ChrisNPDrider 9" DC motor, >140 volts, remove that big 1... Feb 28 2008, 07:24 PM
356 144 volts and 12volt batteries don't look to b... Feb 28 2008, 07:33 PM
neo914-6
144 volts and 12volt batteries don't look to ... Feb 29 2008, 09:03 AM
sean_v8_914 bump Mar 5 2008, 01:24 PM
356 Put down the crack pipe and answer my last email o... Mar 5 2008, 02:44 PM
r_towle never got one...send it again...
just got the COA.... Mar 5 2008, 03:01 PM
neo914-6 Mike,
Maybe you can buy a converted car and trans... Mar 5 2008, 09:06 PM
356
just got the COA... Mar 5 2008, 09:28 PM
356
Mike,
Maybe you can buy a converted car and tran... Mar 5 2008, 09:29 PM
buck toenges What about capacitors with batteries? Read someth... Mar 11 2008, 09:19 AM
swl
What about capacitors with batteries? Read somet... Mar 11 2008, 11:32 AM
smontanaro Where I'm a little skeptical is in a capacitor... Mar 11 2008, 08:31 PM
swl too cool skip. 10,000 fold improvement would do t... Mar 12 2008, 08:29 PM
shelby/914 Just sold a tub to a guy in Aurora for an electric... Mar 12 2008, 08:47 PM
Beanie Boy Well the current 914 is too nice to convert...gonn... Mar 12 2008, 10:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:19 PM |
