What else should CFR Tangerine do to my 73 2.0?, Help me spend my money |
auerbach |
Mar 1 2008, 11:12 PM
Lee David Auerbach, Esq Group: Members Posts: 235 Joined: 26-July 07 From: Westchester, New York Member No.: 7,947 Region Association: MidAtlantic Region |
At the suggestion of the board, I am bringing my 76 914 with a 73 2.0 (dual Webers) to Chris to have the engine and drive train looked at. I already have a new cam on the list. I'm also considering SS headers and break and fuel lines.
Any one else have any constructive suggestions OTHER THAN dropping in a V8 from a Cayenne GTS? Thanks. |
sww914 |
Mar 1 2008, 11:17 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
How much money do you want to spend? What else does the car have? If it has sagging 75# springs in the back I'd do something about that. If the pistons and cylinders aren't too fresh I'd throw a set of 96's with higher compression at it too. Valve job and maybe a wee bit of porting?
So.Cal.914 |
Mar 2 2008, 01:55 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
How much money do you want to spend? What else does the car have? If it has sagging 75# springs in the back I'd do something about that. If the pistons and cylinders aren't too fresh I'd throw a set of 96's with higher compression at it too. Valve job and maybe a wee bit of porting? (IMG:style_emoticons/default/agree.gif) Suspension wise, what do you have? (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 01:57 AM |
