| Brando |
Feb 29 2008, 05:26 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
I can't plop down the $1k+ for a tangerine, so I need some direction on an inexpensive, durable (read: wont rust like madness), clean (read: won't leak so I can fab up heat). I'm not sure what a decent one will cost... Definitely looking for a boost over SSI's in performance.
My guesses are... Euro-Race Kerry Hunter ??? thanks for your input. |
| purple |
Mar 3 2008, 07:47 AM
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
I have a eurorace header and it sounds very nice. it's a bit of a bitch to work around and mine leaks at the collector, but it has little stub pipes that make in easy to take on and off. you need to modify the clutch pulley bracket to make the clutch cable not melt on the header...that's what i'm dealing with right now
Brando Best inexpensive header Feb 29 2008, 05:26 PM
dr914@autoatlanta.com
I can't plop down the $1k+ for a tangeri... Feb 29 2008, 05:34 PM
Brando Sweet. If I ever go six, I can use an MSDS header ... Feb 29 2008, 10:01 PM
Maltese Falcon
Sweet. If I ever go six, I can use an MSDS header... Mar 1 2008, 04:57 PM
lotus_65
Sweet. If I ever go six, I can use an MSDS heade... Mar 4 2008, 05:30 AM
Vacca Rabite
Brando, the T-4 race header that we build is ONL... Mar 4 2008, 07:48 AM
lotus_65
[quote name='lotus_65' post='1004689' date='Mar 4... Mar 4 2008, 08:02 PM
Phoenix 914-6GT http://www.triadwestperformance.com/ Mar 1 2008, 11:20 AM
Brando Thanks Marty, I greatly appreciate your reply. I s... Mar 2 2008, 09:26 PM
Maltese Falcon [quote name='Brando' post='1004233' date='Mar 2 20... Mar 3 2008, 08:59 PM
Vacca Rabite
I have a eurorace header and it sounds very nice.... Mar 3 2008, 09:57 AM
purple
I have a eurorace header and it sounds very nice... Mar 3 2008, 12:09 PM
jasons
Did you put header wrap on the header, or a ther... Mar 3 2008, 05:34 PM
Racer Chris One way to help the cable clear the header: Mar 3 2008, 05:08 PM
purple
Int... Mar 3 2008, 08:28 PM
Racer Chris
In... Mar 4 2008, 08:43 AM
purple
[quote name='purple' post='1004596' date='Mar 3 2... Mar 4 2008, 09:19 AM
purple hold on...13ga sheet metal? as in .0897 inches thi... Mar 4 2008, 05:26 PM
jd74914
hold on...13ga sheet metal? as in .0897 inches th... Mar 4 2008, 08:19 PM
Vacca Rabite as sheet metal goes, 13 gauge is kinda thick. You... Mar 4 2008, 05:28 PM
purple whelp, I found some 12ga :evilgrin: galvanized st... Mar 4 2008, 10:48 PM
Vacca Rabite
whelp, I found some 12ga :evilgrin: galvanized s... Mar 5 2008, 01:08 PM
Racer Chris The ones I supply with my headers have the bolt ho... Mar 5 2008, 02:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:27 PM |
