QUOTE(purple @ Mar 3 2008, 08:47 AM)
I have a eurorace header and it sounds very nice. it's a bit of a bitch to work around and mine leaks at the collector, but it has little stub pipes that make in easy to take on and off. you need to modify the clutch pulley bracket to make the clutch cable not melt on the header...that's what i'm dealing with right now
Did you put header wrap on the header, or a thermal sleeve on the cable (or both?)
From what I have read, at minimum you need the sleeve on the cable (I have read both throttle and clutch) or else the heat from the header will wreck them.
Header wrap should also help with engine cooling, as it will direct the heat out the tail pipe, and not let it radiate from the pipes back into the engine and tranny.
Header wrap may allow the header to rust out faster though, as it will allow moisture to collect. I intend to wrap it up anyhow.
Zach
