> 2004 Porsche 911 Nickies Lineup, Thanks to Brad for all his help!
cnavarro
post Dec 23 2003, 07:27 AM
Cylinder Guru
With everyone's input from the forums, here's what the lineup for 2004 is lookling like:
For the 2.0: Still sourcing one. Once I have it in my hands, i'll be able to determine what overbores from the stock 80mm are possible.
For the 2.2/2.4: factory 84mm, 85mm, 86mm (new size, never before offered by anyone)
For the 2.7/2.8: factory 90mm, 92mm RSR, 93mm (bore size used by porsche for racing, a little thin at the skirt for my tastes, but they did it, so why can't we?)
For the 3.0/3.2: factory 95mm, 98mm (or any bore size between 95 and 98). I'm waiting on some factory cylinders for inspection to determine if anything over 98mm is acceptable. All cylinders will be in the later style, fully finned.
For the 3.6/3.8: factory 100mm, 102mm (available with the RS spec 107mm case register or RSR 109mm case register), 104mm (available on both 107 or 109 registers), and possibly larger with an additional resizing of the case and head spigots, as we're waiting on a 3.8RSR cylinder and furthermore inspection of the heads and case to see what the registers can be safely opened up to.
All Kits will come with later model air deflector tin updates and will be available with factory porsche motorsports or ARP head studs, your choice. Tentative pricing is going to be a flat $2999/cylinders only across the board from a 2.0 to a 3.8RSR set.
If anyone has any questions or would like to see anything else added to the lineup, just drop me a line at charles@LNengineering.com. Thanks for your input guys!
Again, thanks to Brad for helping me put all this together!
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Eric_Shea
post Dec 23 2003, 11:13 AM
PMB Performance
Might be a bit close to the 90mm's but for class rules maybe an 89mm set for the 2.0 and 2.2's. I believe the 90's take those short strokers (just) over 2.5L, 89's are a hair under. People have been lusting over the Mahle 89mm racing sets but they're made from unobtainium. Not sure what pistons are available but they could be crafted in a 9.8:1 or 10.?:1 configuration for single or dual plug.
Others... am I whacky here? (IMG:style_emoticons/default/confused24.gif)
cnavarro   2004 Porsche 911 Nickies Lineup   Dec 23 2003, 07:27 AM
ArtechnikA   ...   Dec 23 2003, 07:37 AM
cnavarro   The six cylinder set of head studs is actually mor...   Dec 23 2003, 08:33 AM
ArtechnikA   ...   Dec 23 2003, 08:45 AM
cnavarro   Is the pricing the same? Do I have a typo on the w...   Dec 23 2003, 08:59 AM
ArtechnikA   ...   Dec 23 2003, 09:01 AM
cnavarro   Yes, there will be competative pricing offered on ...   Dec 23 2003, 10:40 AM
Brad Roberts   IF ..IF the planets align.. Charles and I should h...   Dec 23 2003, 10:59 AM
Aaron Cox   when is dunkles? do you need to register to show u...   Dec 23 2003, 11:04 AM
Eric_Shea
cnavarro   Ok. So a 2.2/2.4 cylinder with 2.7/2.8 registers, ...   Dec 23 2003, 01:00 PM
ArtechnikA   ...   Dec 23 2003, 01:19 PM
cnavarro   Let me try to reprase my question. The 84mm cylind...   Dec 23 2003, 01:25 PM
ArtechnikA   ...   Dec 23 2003, 01:35 PM
bernbomb914   I"m still confused as why the 4 cly eng is the sam...   Dec 23 2003, 01:38 PM
Scott Carlberg   Charles/Brad/Anyone...??? could someone please e...   Dec 23 2003, 02:13 PM
bernbomb914   They are beautiful lightweight alum. cylinders tha...   Dec 23 2003, 02:26 PM
redshift   Nikasil is a plating process used on 911s cyls so ...   Dec 23 2003, 02:28 PM
Eric_Shea
  Dec 23 2003, 02:49 PM
ArtechnikA
  Dec 23 2003, 03:40 PM
ArtechnikA
  Dec 24 2003, 01:15 PM
cnavarro   Hopefully volume increases and the cost of plating...   Dec 24 2003, 03:21 PM
- Lo-Fi Version Time is now: 9th July 2025 - 03:22 PM
