What is this piece on the oil cap?, pic... |
pete914 |
Mar 3 2008, 09:46 AM
Member Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 |
What's the piece on the oil filler cap and what is its purpose?
(IMG:http://i15.ebayimg.com/03/i/000/de/24/5f47_1.JPG) |
ClayPerrine |
Mar 3 2008, 11:02 AM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
FYI... Dave, that won't work on this engine. This is a 1.8, and it doesn't have a PCV valve.
pete914 |
Mar 3 2008, 01:03 PM
FYI... Dave, that won't work on this engine. This is a 1.8, and it doesn't have a PCV valve. Okay, right now I have a tube running from the oil filler to the air cleaner on my single carb setup. should I do the same thing with duals (about to switch)? just have the blowoff go to one or both carbs? thanks guys... |
ClayPerrine |
Mar 3 2008, 02:51 PM
FYI... Dave, that won't work on this engine. This is a 1.8, and it doesn't have a PCV valve. Okay, right now I have a tube running from the oil filler to the air cleaner on my single carb setup. should I do the same thing with duals (about to switch)? just have the blowoff go to one or both carbs? thanks guys... That depends on the filler cap. The 1.8L has a different oil filler assembly because of the L-jet injection. This is a 1.8L filler cap, so it has a very large hole on it to hook to the air intake tube. It also doesn't have a PCV valve or head breather tubes. If you have a 1.7 or 2.0, you have a different filler cap assembly, and Dave's directions are spot on. |
pete914 |
Mar 3 2008, 04:57 PM
this is what I ordered. How do you suggest I hook it up? one tube coming from the oil filler cap into this box and then vent out the engine tin? seems a little funky...
The guy at CB performance suggested running tubes from the valve covers and then into the air cleaners (drill a hole). Suggestions? (IMG:http://www.cbperformance.com/catalogimages/1754.jpg) |
Lo-Fi Version | Time is now: 7th June 2024 - 03:50 PM |
