Wire size, Battery to starter |
spunone |
Mar 3 2008, 08:30 AM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
What size wire should be used to go from Battery to Starter?Thanks
Dr. Roger |
Mar 4 2008, 02:25 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
Hey Paul,
Another thing to consider is strand count. The more strands, the more pliable, and longer life it will live. I'd go larger than 0 IMHO. .32" diameter seems a little small for a couple hundred Amps, doesn't it? =-O |
jk76.914 |
Mar 4 2008, 05:38 AM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
Hey Paul, Another thing to consider is strand count. The more strands, the more pliable, and longer life it will live. I'd go larger than 0 IMHO. .32" diameter seems a little small for a couple hundred Amps, doesn't it? =-O (IMG:style_emoticons/default/agree.gif) You can get wire with much higher strand count at boating supply stores. It's much more flexible. I went locally to West Marine and bought mine by the foot. The strands in their "marine grade" battery cable are individually plated as well, for corrosion resistance. They also sell heavy duty lugs, shrink sleeving with sealant inside, and an inexpensive lug crimping tool. You put the lug in it, put the cable in the lug, and whack it with a hammer. Shrink the sleeving over it, and you're done. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:04 AM |
