> Crankcase breather with carbs., How do you attach a hose to the filters?
Thack
post Nov 11 2007, 11:32 PM
Post #21
For those running dual carbs, how do you attach a crankcase breather hose to the filters? Especially if you have K&Ns, which I plan to replace. Do you run two hoses? Got pics? (IMG:style_emoticons/default/sawzall-smiley.gif)
rhodyguy
post Mar 4 2008, 09:20 AM
Post #22
or...with 2.0 heads with the drain/vapor return tubes, you run a single vent line from the oil fill tower to the cb style foam filled box and lines from the outlets on the box to the heads. you need to ensure the bb is mounted high enough for the oil to flow to the heads and not puddle in the lines. with the cb bb, squeezing the dirty oil out of the foam filter and soaking up the small ammount in the bottom should be considered part of routine maintenance.
k
Thack   Crankcase breather with carbs.   Nov 11 2007, 11:32 PM
So.Cal.914   For those running dual carbs, how do you attach a...   Nov 11 2007, 11:59 PM
pete914   hijacking the thread here...pics anyone?   Mar 4 2008, 06:32 AM
SGB   I wouldliketo see this too. I don't think I h...   Mar 4 2008, 07:06 AM
Joe Ricard   It's easy. YOU DON'T. Get a CB or EMPI b...   Mar 4 2008, 07:44 AM
pete914   so just run a tube from the oil filler to the brea...   Mar 4 2008, 08:58 AM
Joe Ricard   Why? All you are doing is sucking oil into the c...   Mar 4 2008, 09:15 AM
pete914   Do I need the valve covers to be vented? Right now...   Mar 4 2008, 10:56 AM
rhodyguy   or...with 2.0 heads with the drain/vapor return tu...   Mar 4 2008, 09:20 AM
rhodyguy   just venting to the underside of the car is not th...   Mar 4 2008, 11:34 AM
Joe Ricard   Word. DO NOT vent it under the car. You will end...   Mar 4 2008, 11:39 AM
SirAndy   Word. DO NOT vent it under the car. You will en...   Mar 4 2008, 11:57 AM
akellym   this works very well for me.   Mar 4 2008, 11:59 AM
pete914   sirandy, so you have one line from oil filler to p...   Mar 4 2008, 03:14 PM
SirAndy   sirandy, so you have one line from oil filler to ...   Mar 4 2008, 04:05 PM
orange914   heres a picture with nipple. anyone got a puke ca...   Mar 4 2008, 04:26 PM
pete914   anyone know the stock years they had the vents? I...   Mar 4 2008, 05:51 PM
Gint   anyone know the stock years they had the vents? I...   Mar 4 2008, 08:34 PM
purple   anyone know the stock years they had the vents? ...   Mar 4 2008, 10:54 PM
chris914   Does anyone have pictures of how they added them t...   Mar 4 2008, 06:52 PM
So.Cal.914   Now this is just me but I would rather drill the h...   Mar 4 2008, 07:12 PM
sww914   If my heads weren't already vented like the on...   Mar 4 2008, 07:54 PM
orange914   this link will take you to a pair of valve cover b...   Mar 4 2008, 09:33 PM
chris914   this link will take you to a pair of valve cover ...   Mar 5 2008, 03:08 AM
RohJay   I have a set of those. I was wondering were other...   Mar 5 2008, 11:35 PM
SirAndy   I have a set of those. I was wondering were othe...   Mar 6 2008, 02:23 AM
Gint   :agree: "A" breather is better than ...   Mar 6 2008, 06:40 AM
Gint   I received a PM question(s) that I'm going to ...   Mar 6 2008, 06:56 AM
rhodyguy   i imagine those ebay vent items will do the job. t...   Mar 6 2008, 08:29 AM
ruddyboys   my engine doesn't have either head vents or va...   Mar 6 2008, 08:40 AM
pete914   ruddyboys: I bet venting would help. Its the press...   Mar 6 2008, 10:00 AM
So.Cal.914   I am going to throw this out and take my lumps. Wh...   Mar 6 2008, 10:58 AM
Gint   I am going to throw this out and take my lumps. W...   Mar 6 2008, 04:52 PM
Spoke   So were breather vents standard issue on FI 914 en...   Mar 6 2008, 11:11 AM
ConeDodger   I use this CFR Spunone collaboration. The two side...   Mar 6 2008, 11:15 AM
Gint   A very nice set up. Though Chris wants to make at ...   Mar 6 2008, 04:53 PM
CCE   I use this CFR Spunone collaboration. The two sid...   Jun 8 2022, 10:51 PM
So.Cal.914   I don't know if this is the case for sure, and...   Mar 6 2008, 11:20 AM
orange914   there is a hole in the cylinder head but no nipp...   Mar 6 2008, 12:08 PM
barefoot   2056 with Dell 40's head vents connected to ea...   Jun 9 2022, 06:19 AM
- Lo-Fi Version Time is now: 16th June 2024 - 09:45 PM
